Vararam
Old 04-30-2014, 02:58 PM   #1
gatortuba
Drives: 2017 Camaro V6 RS
Spolier Install
I am thinking about installing this spoiler to my 2010 1LT:
http://www.shopchevyparts.com/exteri...-92248201.html
How hard do you think it will be?
What are the chances the color will not match because of fading?
Thanks.
gatortuba is offline   Reply With Quote
Old 04-30-2014, 04:27 PM   #2
mth35115
Drives: 2010 Camaro rs/ss inferno orange
I have a 2010 SS that I installed a new spoiler on, and after taking off the old spoiler there was no indication of any fading in the paint. This was done last fall, I bought my Camaro in Nov 2009.
HOT ROD SS
MTH35115
mth35115 is offline   Reply With Quote
Old 04-30-2014, 04:34 PM   #3
PonyKiller74
PonyKiller74's Avatar
Drives: 2012 Triple Black ZL1 M6
Send a message via AIM to PonyKiller74 Send a message via Yahoo to PonyKiller74
install should be fairly easy with factory holes and such. Shouldn't have any paint fade. Install maybe 20 minutes
CenterForce DYAD Dual Disc Clutch, JDP stage 2 Clutch Reservoir, Rotofab CF CAI with Big Gulp and WW Reservoir Relocate, Stainess Works LT Headers and Retro Cat-Back with Cat Delete, MGW ST Shifter with custom Knob, CF Tail light Bezels, more to come...
Build Thread for my Z is in the works.....
PonyKiller74 is offline   Reply With Quote
Old 04-30-2014, 05:02 PM   #4
freddyD
Drives: 2020 rally green rs
yea that spoiler I like
freddyD is offline   Reply With Quote
Old 04-30-2014, 05:16 PM   #5
Eddiefuzz
Eddiefuzz's Avatar
Drives: 2011 RS
Then you have to hook up the third brake light...It isn't that hard.
Eddiefuzz is offline   Reply With Quote
Old 04-30-2014, 09:56 PM   #6
gatortuba
I'm just worried about drilling the holes.
Old 05-01-2014, 02:13 PM   #7
Jcm
Drives: 2011 ss
I installed that spoiler on my 2011 SS..they do look the best to me..
It does use factory holes in the SS for the trunk lid..my troubles came when I took the old stock factory spoiler off,,it is not the same footprint as your new one,,so it did pull the paint up ,several small spots on the ends just a little where the new spoiler does not cover,,(paint stuck to the old rubber cushioning strip) so go real easy there..
It took me about 2 hours because the 2 side pieces were a real bitch to start the the nuts on those studs,,there is very,very,little room for your hand or fingers to start the nuts..you'll probably be flopping around in the trunk as I was..
Mine did come with a paper template that helped with drilling the side pieces..
Brake light is no problem .pull back seat back loose, gently pull plastic panel loose (It's under passenger side small window..then it's simply plug and play..
Good Luck.
Jcm is offline   Reply With Quote
