Old 01-27-2014, 02:27 PM   #1
Retro69
Retro69's Avatar
Drives: 2018 Camaro ZL1
20 X 9 With 275s on All Four Corners: Is There a Down Side?
I bought a second set of MS wheels with the intention of going with a square setup with 275s all the way around. Is there any downside to doing this?
Sent from my iPad using Tapatalk HD
Retro69 is offline   Reply With Quote
Old 01-27-2014, 02:54 PM   #2
Jcm
Drives: 2011 ss
Just a little more drag from a wider tire..( fuel mileage )
Worth it to me ,,wider stance fills up the fender especially if lowered 1.4"
Jcm is offline   Reply With Quote
Old 01-27-2014, 04:39 PM   #3
VR Baron
SoCal Camaro5 Race Team
VR Baron's Avatar
Drives: 2021 Shadow Grey Camaro 2SS 1LE
Not that I know of. Handle better, rotate the tires, front end will feel more stable and less understeer
VR Baron is offline   Reply With Quote
Old 01-27-2014, 05:19 PM   #4
LuSe4
LuSe4's Avatar
Drives: 2013 Camaro 2SS RS LS3
The downside is trying to find someone to sell just the rear wheels and tires, but you already have yours so.........no downside, only upside!
-2013 Summit White over Inferno Orange 2SS RS-
-2014 White Diamond Silverado Z71 Crew Cab Short Box-
LuSe4 is offline   Reply With Quote
Old 01-27-2014, 05:25 PM   #5
AG1LE
AG1LE's Avatar
Drives: '14 1LE
That's what I want to do...if I can ever get my hands on a set of '13 or '14 rears. I also plan to add some hub-centric spacers (H&R or Eibach) to fill out the wheel well. All of this as an intermediate "fix" until I can afford the new wheel/tire setup I want...
AG1LE is offline   Reply With Quote
Old 01-27-2014, 11:28 PM   #6
Retro69
Retro69's Avatar
I, too, was hoping to find just the rears but got a reasonable deal on all four in good shape. I am planning on using the four 8"ers for some snow tires for next winter so at least they won't go unused.
I like your idea of the spacers... I'll have to give that some thought. Also, like you, this is an intermediate "fix" until funds allow some nice, lightweight forged 10-11" on all four corners.
Old 01-28-2014, 03:53 AM   #7
SS PANTHER
SS PANTHER's Avatar
Drives: 2013 SS Supercharged Convertible
I like my 275 square setup.
SS PANTHER is offline   Reply With Quote
Old 02-22-2014, 08:01 PM   #8
Kent2010
Drives: Camaro SS
The rear is no problem (obviously), but on the front, OEM 275/40-20 tires on standard OEM 20x9 rims *will* rub the frame ahead of the front axle line but only at full steering lock.
Another brand tire (non-Pirelli)may rub less or it may rub more, as actual tire dimensions vary even at the same stated size, depending on brand.
I just did a test fit of my OEM rear wheels/tires on the front of my 2012 SS today, so the info is fresh in my head. Not sure if the rub will be enough to bother me. I think a small spacer (5mm) would eliminate the interference.
Cheers,
Kent
Kent2010 is offline   Reply With Quote
Old 02-22-2014, 09:34 PM   #9
Retro69
Retro69's Avatar
Cheers,
Kent
I've had my 9/275's up front for a couple weeks now. I'll have to take a peek to see if I'm rubbing there. BTW... I did my first competition track event at Miller Motorsports Part a week ago and took third place in my class. I'm sure the wider rubber up front helped more that the driver's skill
Old 02-23-2014, 10:04 AM   #10
Drives: '20 Corvette Stingray
been runnin8g that combo for about a year and a half.....there is no down side.
