Go Back   CAMARO6 > Engine | Drivetrain | Powertrain Technical Discussions > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing
AWE Tuning
Old 05-30-2016, 07:14 AM   #1
hotlap
hotlap's Avatar
Rear Differential Fluid Spec has changed
I noticed the second printing of the Camaro owners manual now calls for fluid 88900401 with limited slip additive 88900330.
The first printing called for fluid 88862624 only.
A deliberate change was made so I assume they are not equivalent. My 4/19/16 build came with the second printing
http://www.chevrolet.com/content/dam...ers-manual.pdf
Ronald Reagan -
Old 05-30-2016, 11:08 AM   #2
enzia35
Drives: '16 Garnet Red 1SS
Interesting. Now, is the rear end fluid something that should be changed within the first 5k miles or so?
'16 Camaro 1SS
'18 Miata GT
Gone: '01 Camaro, '14 Camaro, '90 Miata
enzia35 is offline   Reply With Quote
Old 05-30-2016, 02:00 PM   #3
mbar
Drives: 2016 1SS
Also makes me wonder how many bottles of the additive should we use?
1SS, Black, Black Wheels, A8, MRC, NPP
mbar is offline   Reply With Quote
Old 05-30-2016, 02:06 PM   #4
hotlap
hotlap's Avatar
By the book, the rear axle fluid doesn't need to be changed until 45,000 miles under normal of severe driving conditions. If you track the car they recommend that you not do it until 1,500 miles and then change the fluid after the first event.
I change oil, transmission and differential after the 1,500 mile break in to ensure there isn't any assembly crap in the system. I found this chuck stuck to the plug magnet when I changed my ZL1 at 1,500 miles.
Ronald Reagan -
Old 05-30-2016, 02:19 PM   #5
hotlap
hotlap's Avatar
You add one 4 oz bottle of additive. My GTO required the same additive and the bottle said add complete bottle when filling. Problem is 4 oz is 0.125 quart and fill takes 1.2 quarts so I still bought 2 quarts of fluid so I wouldn't come short.
I use a fluid pump so some fluid will be lost ($7 on Amazon). Pump third quart of fluid into axle. Then squeeze the bottle of additive in and top off. Go drive figure 8 pattern to mix it up.
Ronald Reagan -
Old 05-31-2016, 01:21 PM   #6
drivingagain
drivingagain's Avatar
Drives: 2015 Tiger XCX,2016 Camaro 1SS,LBZ!
This is what the 16' SS rear diff fluid plug looks like at 1500 miles as well. Mine was minus the chunk. Changed my rear end oil at 1500 miles.
drivingagain is offline   Reply With Quote
Old 05-22-2017, 07:19 AM   #7
IMadeYouReadThis
IMadeYouReadThis's Avatar
Drives: 02 Camaro SS 6M / 11 GMC Sierra
I ordered some fluid from the GM dealership that I bought my car from here in Canada and they said nothing about adding the limited slip fluid. They told me that mine takes 1.1 liters so I ordered two bottles it's good I came across this thread I'm going to have to get the new order me some of the limited slip fluid. I'm going to do it when I hit 1500 kilometers. Planning on doing the first oil change before a thousand kilometers. Has anybody else done the rear end on a V6 manual transmission yet? Anything out of the ordinary to watch out for or is it pretty standard lol.
IMadeYouReadThis is offline   Reply With Quote
Old 05-25-2017, 01:10 AM   #8
MatthewAMEL
MatthewAMEL's Avatar
Drives: 2023 CT5 Blackwing
DO NOT ADD friction modifier to the GM fluid.
The revised part includes the friction modifier. It's printed right on the bottle.
2017 HBM SS 1LE
Sold
2023 Wave Metallic
CT5-V Blackwing M6
MatthewAMEL is offline   Reply With Quote
Old 05-25-2017, 11:09 AM   #9
wrankin
Camaros Of Northwest Ohio
Drives: 2016 Black 2SS
The spec change is probably due to the rear end groan that many of us have. Read more about it here:
http://www.camaro6.com/forums/showthread.php?t=440272
First attempt at a fix is to do a couple of flushes with the new fluid that includes the friction modifier.
2023 2SS 1LE Red Hot
2016 2SS Black / Black & Arenaline Red (sold)
2023 GMC Canyon Denali
2013 2SS / RS - AGM / Jet Black (sold)
1970 1/2 Z/28 Classic Copper / Tan (sold many years ago)
wrankin is offline   Reply With Quote
Old 07-09-2017, 02:54 PM   #10
vtirocz
vtirocz's Avatar
Drives: 2017 Camaro 1SS M6
The 2017 manual I received with the car and the latest one published online calls for 88862624 (for the SS diff). The latest 2018 owners manual also calls for 88862624. I wonder why they'd recommend different fluids for 2016 and 2017/2018 SS models?
The TSB from this post also indicates 88862624 is correct for 2016-2017. http://www.camaro6.com/forums/showpo...&postcount=601
For reference, here's the 2018 owner's manual: https://my.chevrolet.com/content/dam...ers-manual.pdf
Old 07-09-2017, 03:27 PM   #11
grampa_ss
grampa_ss's Avatar
Drives: 2016 Camaro 2SS
I have a 2016 SS and my manual says to use the 88900401 with limited slip additive 88900330. I did NOT go that way. I went with 88862624 and the groan is gone.
2016 2SS, MRC, NPP, A8. Procharger P-1X,Stage II,std bypass, 3.9, Alky Meth - 10.84 @129 - DA+2000
New Mods - GPI drop ins, Kooks 2", LT4 fueling, Cam, Circle D Converter, 3.5 pulley & dual nozzle meth.
grampa_ss is offline   Reply With Quote
Old 07-15-2017, 07:26 AM   #12
Eldi Z
Drives: 17' 1SS 1LE GBA-Black
Anyone try this stuff?
BG is supposed to be top notch material, especially for such LSD and other gear applications and some rumors say that the AC Delco stuff is actually made by BG ?
Anyone have a way to confirm this?
Have a look:
https://www.bgprod.com/catalog/drive.../#bg-product-1
Another option, is to get the LS/D concentrate MGC separately and mix with P/N 750
https://www.bgprod.com/catalog/drive.../#bg-product-7
This:
https://www.bgprod.com/catalog/drive.../#bg-product-6
Eldi Z is offline   Reply With Quote
Old 07-16-2017, 02:02 PM   #13
Biscuit.fr
Drives: Red hot ZL1 A10 2017
I changed mine at 1100 on my A10.
Regret not to have it done at 500....
A lot of metallic shit on the magnetic plug, and a dark fluid!!!!!
Do it!
But, I've noticed something different after....
Performance page / trans fluid temperature :
I think but not for sure it was between 100-150F before rear diff change
(Don't remember if I checked that on my 2ss fifty last year or on my ZL1 few months ago),
And on the way back home with the new fluid, the temp stabilized almost at 200F
Have you seen that also?
Is it normal?
Thanks
Biscuit.fr is offline   Reply With Quote
Old 07-16-2017, 03:46 PM   #14
somewhatdamaged
somewhatdamaged's Avatar
Drives: 16' 2SS M6
I concur- also have a 2016 2SS and had tried the change out to 88900301 and LS additive 88900330. The groan was still there - I then swapped the 88862624 and no groan at all - cold start, turns - none.
somewhatdamaged is offline   Reply With Quote
