BeckyD @ James Martin Chevy
Old 04-06-2021, 08:43 PM   #1
AdzyHany
Drives: 2021 camaro ss 1LE
1LE/ZL1 fuel system differences
Hey, I have a 21’ 1LE that I plan to put a Maggie on and I’m looking at making similar power as the ZL1, maybe slightly more. I have read in places that the 1LE might have different fuel system components than the SS? What exactly would I need to upgrade? Also, I’m looking for opinions on piston ring gap (I would rather do water/meth if that alone is safe) thanks!
AdzyHany is offline   Reply With Quote
Old 04-06-2021, 09:26 PM   #2
Puddin
Drives: 2016 Camaro 2SS
The 1le share the same fuel pump in the tank as the Zl1 so you'll have to upgrade the High pressure pump and injectors. As far as ring gap I'd talk to an actual engine builder they will be able to sort you out.
Puddin is offline   Reply With Quote
Old 04-07-2021, 05:17 AM   #3
AdzyHany
Thank you sir
Old 04-07-2021, 08:46 AM   #4
L78toLT1
L78toLT1's Avatar
Drives: Hyper Blue 2016 2SS 6M
If all you're looking for is ZL1 power (~550whp), you can safely get there on the LT1 fuel system & bottom end.
Baby Blue
2016 Hyper Blue 2SS/6m/MRC/NPP/Silver Rally stripes/ZL1 wheels & brakes/GForce DS and axles/ZLE Cradle Bushings/FE4 ARB front & rear/SEMA Grill/Rotofab dry/95mm TB/Magnuson 2300/Full LT4 fuel system/JMS boost-a-pump/E85 Sensor/Ported CID heads from LME/Cammotion PD cam/Thompson Motorsports forged shortblock/catted Kooks 1 7/8 headers /JRE remote tuned
L78toLT1 is offline   Reply With Quote
Old 04-07-2021, 10:23 AM   #5
AdzyHany
I never really researched it but for some reason I was thinking they would hit close to 600whp but that’s not right. I would like to be 600-650whp range
Old 04-07-2021, 01:07 PM   #6
L78toLT1
L78toLT1's Avatar
Stock ZL1's are usually around 550whp. To get to 600 - 650, you will need the LT4 hpfp and injectors.
Baby Blue
Old 04-07-2021, 05:08 PM   #7
AdzyHany
Thank you! Any opinion on ring gap?
Old 04-07-2021, 06:55 PM   #8
Joshinator99
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
If you add the LT4 fueling, you can add some E into the mix. That will help cool the charge significantly and help prevent an issue with the ring gaps. I know that statement will stir the pot for some, but every single grenaded LT1 stock short block I’ve seen was due to a fuel or tuning issue. Every time, without fail. Fuel it right and you’ve done yourself a huge favor.
Old 04-07-2021, 07:16 PM   #9
Puddin
Yeah it's usually when they band-aid it with meth because they don't want to spend the money.
Old 04-07-2021, 07:21 PM   #10
Eldi Z
Drives: 17' 1SS 1LE GBA-Black
Can you safely get away without Meth also for little above ZL1 power levels (~570-580 WHP) on a SBE LT1 using the LT4 fueling with standard 93 off the pump?
*Pulley size targeting no more than ~ 7-8 PSI boost?
Eldi Z is offline   Reply With Quote
Old 04-07-2021, 08:06 PM   #11
Joshinator99
Exactly. The distribution is too uneven and meth alone doesn’t pull enough heat out of the chamber. IMO.
Sure, but I’d use a 50/50 water/meth mix instead of just meth. You’ll only need 6-7 psi of boost to get to that power level anyway, so not much heat there thankfully.
Old 04-08-2021, 09:58 AM   #12
JANNETTYRACING
JANNETTYRACING's Avatar
Hello and welcome to Camaro6 family.
I offer complete power packages to meet your goals
Our Street brawler package features supercharger, cold air kit,LT headers JRE custom tuning for up to 580 RWHP max
Add our LT4 fuel system upgrade for up to 615 on 93 octane.
Ring gaps are a non issue if tuning and fuel systems are correct.
We have Many cars with totally stock long blocks plus our Terminator cam and blower on E-60 making 750 RWHP reliably for years now.
www.jannettyracing.com
email tedj@jannettyracing.com
Old 04-08-2021, 02:01 PM   #13
AdzyHany
I’m up in Canada and we don’t have E. My only real option is 93 or 94 with water/meth
Old 04-09-2021, 07:41 AM   #14
JANNETTYRACING
You do not need water meth and I strongly recommend against it.
