11-19-2020, 08:39 AM | #1 |
Instagram- _2sslow_
Drives: 2016 Camaro 2SS Join Date: Dec 2015
Bouncy and loose front end on lowering springs... HELP
I have h&r lowering springs and since I’ve installed them my front end has been very bouncy and loose. I was told my shocks and struts are good. Please help
Instagram- _2sslow_
2011 Camaro LT RS (Sold) 2011 Range Rover Sport HSE (Sold) 2016 Camaro 2SS NPP, TSP headers & Xpipe, Skid e85, CAI Intake, MSD IM, 95m TB, BigPowerRacing Tune, H&R Lowering springs, BMR sway bars |
11-19-2020, 10:57 AM | #2 |
yup they may be bad or too low
11-19-2020, 11:28 AM | #3 |
Drives: 2016 2SS Join Date: Apr 2020
Are you on OEM struts?
11-19-2020, 01:14 PM | #4 |
Instagram- _2sslow_
Instagram- _2sslow_
11-20-2020, 07:22 PM | #5 |
Instagram- _2sslow_
Instagram- _2sslow_
11-21-2020, 01:53 AM | #6 |
Drives: 17 hyper blue 2SS M6 Join Date: Mar 2018
This is the first I've read about anyone having this issue, definitely not my experience with BMR springs. I'd suggest taking it back to the shop and checking the installation. Even if you did the work yourself, I don't see how it doesn't need to come back apart to inspect it.
11-23-2020, 02:55 PM | #7 | |
Drives: Race Car Join Date: Sep 2009
I suspect he has Shock issues |
11-24-2020, 10:46 AM | #8 |
Instagram- _2sslow_
I apologize they’re BMR not HR and it’s not a shock issue I had them checked
Instagram- _2sslow_
11-24-2020, 03:45 PM | #9 |
Springs hold the car up - Shocks (Dampers) control the Motion. Without Shocks or with Bad Shocks, you would be Bouncy.
How were your Shocks & Certified? |
11-24-2020, 05:28 PM | #10 |
Drives: 2019 SS Join Date: Apr 2020
You most likely have limited shock travel now since lowered, it happens until you run a shorter shock. I raised mine back up cause looking cool doesn't beat a good ride. Go with coilovers.
11-24-2020, 09:21 PM | #11 |
Drives: 22' Porsche PDK GT4 Join Date: Mar 2018
lowering springs are always going to make a car more bouncy. The springs have to match the shock damping curves.
Lowering springs are for looks only, NEVER a good idea if your goal is to improve handling. You need coilovers to do it right if you want a lower stance.
Current:
22' Porsche PDK GT4 (MCS 2-way remote dampers) Previous: 18' NFG 2SS 1LE (ZL1 1LE solid rear cradle bushings & Corsa Exhaust) 16' F80 M3 (Ohlin R/T Coilovers) 13' Audi TTRS (APR Stage 1, MSS Springs) 09' C6 Z06 08' E90 M3 06' 335i (KW V2 Coilovers) 03' C5 Z06 |
12-02-2020, 05:42 PM | #12 |
Did you time the bushings after the spring install?
12-04-2020, 09:27 AM | #13 | |
Drives: 2017 Camaro SS 1LE Join Date: Oct 2018
It has been said that it's rarely a good idea to apply words like NEVER and ALWAYS, as you'll only look foolish in the end. |
12-04-2020, 02:20 PM | #14 |
Drives: 2019 Camaro 2SS Join Date: Aug 2020
Or do the GM kit that comes with matched shocks. May not drop as much but seems most folks that have it love it (ride/handling)
2019 Shock 2SS A10. 2650@10psi/LPE HPFP/XDI+30/LT4 LPFP+JMS/Soler 95mm/Rotofab, E65, CSP 2” Headers/GESI GenII Cats. MM Wild/GM SG3 suspension/1LE Brakes, Velgen VF5 Wheels/GY SC3. JRE Tuned.
