03-05-2019, 07:53 AM | #1 |
Drives: 2019 ZL1 1LE A10 Join Date: Jan 2015
A10 "on-track" shifting logic
Does anyone know how to get the A10 to drop into the "on-track" shifting logic without pushing the car into a turn or going WOT etc? If you don't know what I'm talking about you can stop reading this thread now.
Great, okay, so you own an A10 car and you know that when the car is on track (or thinks it might be on track) it shifts very aggressively, downshifts into every gear, holds the gears longer, snaps shifts off very rapidly. Putting the car into "Track Mode" on the street doesn't automatically do this. In fact, my ATS-V A8 trans acts the same exact way. There are times that I'd like to just push a button and get this shifting logic, spirited driving on the street or just wanting to show someone how the trans actually works on track but just driving down the street at legal speeds. So, besides putting the car through a series of situations that trigger track mode shifting, has anyone figured out a way to make this happen with a touch of a button? Thanks.
Ryker #29
2019 ZL1 1LE A10 2015 Z/28 #809 |
03-05-2019, 09:04 AM | #2 |
Drives: 2017 Red Hot ZL1 Join Date: May 2015
If I'm in track mode and I blip the throttle past halfway once that transmission is ready to play. I know what your asking and it'd be a nice option if we had a button to hit but I haven't seen it. You may be able to manipulate that with a tune but I'd imagine daily driving like that would get old quick.
03-05-2019, 09:08 AM | #3 |
Drives: 2017 ZL1 A10 Summit White Join Date: Apr 2018
I have been wanting this since I had my 2012 ctsv. It was even harder to get in that mode than my ZL1. I would buy a device if someone invented one. I imagine a tuner might be able to achieve this but maybe it would always be on which would be kinda crazy. The only way I know is to stab the throttle very quickly. The only problem is that it deactivates in about 8 seconds which is really annoying. The only way to keep it going is to brake hard, accelerate hard, or take a high g turn to simulate being on a track.
03-05-2019, 09:13 AM | #4 |
Drives: 2023 Black ZL1 Auto Join Date: Oct 2009
You should have the option to turn the performance shifting mode on, off, or automatically activate based on driver input in the settings menu. There's no reason it has to be automatic. Too bad we can't ask Al about it anymore.
03-05-2019, 09:18 AM | #5 |
Drives: ZL1/335i Join Date: Apr 2014
A quick stab of the throttle seems to do it for me. Just a blip is needed to get into the performance shift mode. I know that’s not a button, but it can be done easily without the car accelerating or doing anything else crazy.
03-05-2019, 10:11 AM | #6 |
Drives: Rally Green 2020 ZL1 1LE A10 Join Date: Jul 2018
Agreed with the above.
Seems to work fine by doing that for me as well. I drive in track mode with suspension on sport and steering on street so maybe that helps it engage quicker or with less of a throttle stab I don't know but its pretty responsive when I ask it to get into performance shift mode. I like the transmission in track mode for regular driving and wish that was a selection more then then performance shift mode honestly. |
03-05-2019, 12:53 PM | #7 |
Drives: A10 LT4 Join Date: Aug 2016
I asked the same when I took possession back in early March 17...short answer is no.
You would think a sparky could design a switch. |
03-05-2019, 04:54 PM | #8 |
Drives: Fast Join Date: Mar 2015
I think what OP is asking for is much beyond the "Performance Shift Mode Activated" you get by blipping the throttle that merely holds a gear, mildly downshifts if you brake soon after, and disappears after 10 seconds or so of regular driving. If you recall, this car has I believe three aggression levels that are determined by a combination of algorithms and sensors on the car. There is no way to my knowledge to get this put onto a switch but man would that have been genius. Porsche does that with the PDK, where it holds gears, downshifts aggressively, etc. with a push of a button. The only way to get it into the max aggression mode is by pushing the car for a period of time undisclosed to us.
03-05-2019, 05:02 PM | #9 |
Drives: 2017 ZL1 A10 Nightfall Grey Join Date: Nov 2017
I regularly use Performance Shift Mode by punching the throttle. Just to engine break or heading into a turn...i do it all the time and love it! I cruise around in sport most of the time...wont work in Tour. It is super easy and works beautifully.
03-05-2019, 05:29 PM | #10 | |
03-05-2019, 08:13 PM | #11 | |
- A10 Track Mode selectable via software (3 levels of aggression, great) - Cold Air Intake Calibration - Long Tube header Calibration (offroad/on-road) - eLSD modes for various situations (autoX-drag,etc) - ABS modes for different brake compounds/tires sizes/stickers - Airbag and Seat harness firmware updates for on track only configurations It doesn't make sense to me, these dealers could really capitalize on so much, but they stand there flat footed.
Ryker #29
03-05-2019, 08:15 PM | #12 | |
03-05-2019, 10:00 PM | #13 | |
Drives: Grandad's C2 L89 Join Date: May 2017
2018 ZL1 1LE sw/PDR
03-06-2019, 03:02 AM | #14 |
Drives: 2019 ZL1 A10 Join Date: Aug 2018
Absolutely. The throttle stab is so quick the car barely reacts.
