11-25-2023, 08:43 PM | #1 |
Drives: 1SS 1LE Join Date: Nov 2023
Automatic SS 1LE HUD shift lights
Hey guys
I've seen some videos online, as well as on the car manual, that the HUD in the performance view should have shift lights visible as well as current gear. I've tried getting it to work but it doesn't seem like the HUD would show anything other than G-force, speed and RPM when in the performance view, there's no gear indicator and no shift lights. Is this intended or is there a way to activate them in any way? Couldn't find anything in the menus either. Thank you! |
11-25-2023, 09:28 PM | #2 |
Are you sure that you are in the performance mode of the HUD display? Sounds like you might be, but odd that you don't see the shift lights.
Are you able to cycle through the different HUD display modes using the dash button to the left of the steering wheel? If your car is new and you don't have 1500 miles on it yet (the break in period) maybe the shift lights purposely are turned off to discourage runs up to redline. I can't recall if I had shift lights during the break in period. But they certainly worked after 1500 miles. |
11-25-2023, 10:16 PM | #3 | |
Long hauler
I believe you have to be in Track mode for the lights to appear. The dealership still has my car otherwise I’d test for you but try it in track mode on the RPM page like this video shows
2022 2SS 1LE - Window Sticker - Cold Air Inductions Elite Carbon CAI
2016 1LT v6 - Totaled Happiness: Infinite |
11-26-2023, 08:40 AM | #4 | |||
My car has 5K kilometers so over 3K miles, and I'm able to cycle through the modes, the lights don't show up on any, including the performance display thats shown in the video. I'll remind again that mine's an automatic but it seems like it should be there still Quote:
I'm in track mode, and the shifter is in the manual position, TC/Stability off and full throttle manually upshifting through the gears. The lights never show up Do you know if it needs to be enabled somehow? I've watched that video as well but mine doesn't show the gear I'm in, neither does it show the shift lights. |
11-26-2023, 08:51 AM | #5 |
https://www.camaro6.com/forums/showthread.php?t=566101
This guy seems to confirm that the A10 SS 1LE does have it.. Very curious as to why mine doesn't show up |
11-26-2023, 08:58 AM | #6 |
Drives: Chevrolet Blazer Join Date: Oct 2021
You tried cycling through the HUD configurations and you still do not see the shift light, I recommend a trip to your dealer. I've never had an issue with it. One thing to note, if you do not use the paddle shifters or manually shift using gear select it will only display 'D'. If you shift the gears yourself it will show the gear you are in.
2023 2SS 1LE Radiant Red, A10, PDR, Black Lugs, ACS Rock Guards, ACS ZL1 1LE Side Skirts
11-26-2023, 09:06 AM | #7 |
Retired from GM
Drives: 2017 Camaro Fifty SS Convertible Join Date: Mar 2017
Just wondering if this is something that is tied to one of the unselected pages that ou have to go in and select when setting up the car? For example, the Performance Timers have to be selected in the setup to be usable. Maybe this is similar.
A8 | MRC | NPP | Nav | HUD | GM Performance CAI | Tony Mamo LT1 V2 Ported TB | Kooks 1-7/8” LT Headers | FlexFuel Tune | Thinkware Q800 Pro front and rear dash cam | Charcoal Tint for Taillights and 3rd Brakelight | Orange and Carbon Fiber Bowties | 1LE Wheels in Gunmetal Gray | Carbon Fiber Interior Overlays | Novistretch bra and mirror covers | Tow hitch for bicycle rack | |
11-26-2023, 09:22 AM | #8 | ||
I have tried cycling through them. I think the dealer here would be incompetent as this car has been imported to the US and isnt being sold here locally, directly through Chevrolet. And yeah, I put the shifter lever in manual and shift with the paddles, and it doesn't show D when Im in drive, nor does it show the gear in manual. Quote:
That's what I was thinking as well, that it may be burrowed in some menu option or something, but I didn't seem to find it anywhere in any of the menus... Last edited by Tal_S; 11-26-2023 at 03:53 PM. |
11-27-2023, 09:53 AM | #9 |
11-27-2023, 04:25 PM | #10 |
Drives: Camaro 2SS 1LE Join Date: Jan 2023
Maybe the OP is not turning enough RPM's for the lights to come on.
11-27-2023, 04:33 PM | #11 |
Drives: 2023 Chevrolet Camaro 2SS 1LE Join Date: Jan 2020
This came up in the Zl1 section as well today. You need to be accelerating hard enough. You don't need to go WOT or even above 4500 rpm for it to come up. I have an M6, I am still in break in so I haven't gone WOT or above 4500 rpm, If I have my foot down about half way into the go pedal they will start to come on right around 4k.
Current: 2023 2SS 1LE
Prior: 2016 Camaro 1SS 2007 Mustang GT 2008 Civic Si |
11-27-2023, 05:05 PM | #12 | |
So like I said, I'm full throttle, track mode, in manual, nearing redline, and it doesn't show up. The problem isn't the throttle position.. They never show up regardless of what mode or how much throttle or RPM I'm at. It doesn't show what gear I'm in, either. Do we know for sure that the automatic SS 1LE's have them? |
11-28-2023, 02:21 PM | #13 |
Drives: 2023 Sharkskin Metallic 1LE Join Date: Mar 2018
Never seen them on mine. I have an auto.
11-28-2023, 06:05 PM | #14 |
