Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Regional Forums > USA - California
Old 07-15-2022, 03:27 PM   #1
wawaweewee
Drives: 2013 Camaro SS
Jammer CAI vs KN Drop In
Looking for a CARB intake solution. I'm looking at the Jammer CAI and the KN drop in filter kit thingy and they both cost the same but are obviously different. I just wanted to ask to see if anyone knew which one is better
https://www.diablosport.com/shop/jam...-6-2l-dry.html
vs
https://www.knfilters.com/57-3074-pe...-intake-system
thanks
wawaweewee is offline   Reply With Quote
Old 07-15-2022, 05:44 PM   #2
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Well the first one I have never even heard of, so no on that one. Also the filter is a dry filter and is more of a pain to clean, if you even can. The K&N one is a WET filter, which means it is sprayed with a light oil to help catch all the dust and dirt, and can be easily cleaned and re oiled with the K&N filter recharge cleaner and oil kit, and it will virtually last for ever. I have a K&N Typhoon CAI setup on my Camaro and love it! If I was going to do either one of these, it would be the K&N as they do have great "drop in" filters. Good luck with your choice.
Old 07-15-2022, 07:22 PM   #3
DonM
Camaro #4
DonM's Avatar
Drives: 2017-Hyper Blue Metallic-2LTmanual
I have a K&N drop in for my 2013 LS V6 and I did notice a few MPG increase and smoother idle with the drop in VS the stock paper filter. I've had it in for over 130,000 miles, cleaned it a few times and it's still like new. With it being a 'wet' filter, make sure to clean your MAF sensor every oil change or so, I clean mine every 10k just for insurance and DON'T over oil the filter after cleaning.
Don M
Supercharged LGX + 6 speed manual = FUN!!
DonM is offline   Reply With Quote
Old 07-21-2022, 09:06 AM   #4
HAMBO
HAMBO's Avatar
Drives: Supercharged 2013 AGM 2SS/RS
I have the Jammer CAI and have had no problems with it. Never heard of the brand when I bought it, but it was the only CARB legal one. Have had no problems with it, and it’s a true CAI so should add more power than just a filter change for sure.
2013 AGM 2SS/RS
SLP TVS2300, Edge CAI, 3" Magnaflow catback, BC Racing BR series coilovers, HRE FF15's (20x10 square) with Michelin Pilot Sport 4S's, GM STB, BMR front and rear sway bars and toe links, Prothane subframe bushings and front control arm inserts, JDP rear upper control arm bushings, Elite Engineering catch can. Tuned by Cunningham Motorsports.
1967 Bolero Red 396 SS/RS Convertible
HAMBO is offline   Reply With Quote
