08-07-2015, 10:11 AM | #29 | |
Drives: 2013 AGM ZL1 BELLA* Join Date: Jan 2011
Thank you so much! I will attempt to install tonight and provide pictures... is there any sort of measurement I should use from the top of the third brake light to get a good gauge of the best location for mounting? Also what type and size drill bit did you use and would you suggest using some type of felt material between the Spoiler and bill? Sorry for all the questions... just a little nervous about drilling holes into the painted spoiler.
Roto Fab CAI, Roto Fab Big Gulp, Jokerz ported SC/Snout, LS7 TB ported, ATI Balancer, 28%(10") Lower Pulley, 2" Headers, No Cats,Forza 3way, E85 Flex Fuel sensor , ID850 injectors,, BTR Stage 3, Ron Davis HX, Mighty Mouse CC, APR Splitter, Aero Sports Concepts Splitter Kit, Showstoppers CarbonFiber wicker bill, MRR Wheels. 720rwhp/690tq on 93, 762rwhp E85.
2013 AGM ZL1 Bella* 2010 MGM Toyota Tacoma 2010 CGM SS (Traded) 1996 Black SS (Sold) |
08-07-2015, 10:37 AM | #30 |
Drives: 2010 RS/SS Join Date: Jul 2009
It's really where you think it looks best.
The hole you drill should be the exact size as the shaft of that rubber grommet. Once you slide the rubber in the larger circle part acts as a barrier be ween the bill and the spoiler. So no felt is needed. Sent from my SM-G900T using Tapatalk |
08-08-2015, 10:14 AM | #31 |
Drives: Black '15 Camaro ZL1 Join Date: Nov 2014
This may be a stupid question, but won't these run the risk of being torn off under high speeds? They screw into rubber grommets?
08-14-2015, 12:11 PM | #32 |
From the way it felt and looks, as you tighten down the screws, the washers compress making them alot bigger in the hole. I pulled pretty damn hard after install and it wouldn't even move.
08-14-2015, 12:14 PM | #33 |
08-17-2015, 04:24 PM | #34 |
Just an update on the way this spoiler held up... This weekend I had the car over 150 and the spoiler held up just fine. Also sustain some speeds for small durations of 120-130 and still good to go.
08-18-2015, 06:58 PM | #35 |
Thanks for the update.
04-15-2016, 09:43 AM | #36 |
Drives: 2013 Camaro ZL1 Join Date: Apr 2016
CF Wicker Bill
Hi,
Are you still doing the CF Wickerbills? I would like to get one for my 13 Z. Please PM me. |
