dave@hennessey
Old 03-16-2014, 01:37 PM   #1
thespymaster
thespymaster's Avatar
Drives: C7 / ZL1 / SS / trucsk
ZL1 - ENGINE POWER IS REDUCED !
** Yes, re-post as now aiming specifically at owners of ZL1's
So it happened to me yesterday with just under 18,000 miles on the odometer for the first time.
I've been doing some online checking and it appears a lot of 5th Gen Camaro's are experiencing this same D.I.C message with various symptoms being the root cause of the "ENGINE IS REDUCED POWER" message.
First, who has had them message and what was your repairs?
Second, at what mileage was on the odometer when it first displayed the message?
Third, is your 5th Gen Camaro stock or modified?
** I'm seeing that mostly stock 5th Gen's are getting this "ENGINE IS REDUCED POWER" message.
Lastly, anyone know of any known TSB's for this ?
I took no chances, once it happened to me yesterday , I pulled over and pressed OnStar for diagnostics and over 8 different trouble codes so, I had them tow to the nearest Chevy dealership.
2014 C7 Stingray 3LT/Z51
2013 Camaro SS
2012 Camaro ZL1 - 850 HP
2015 GMC Denali 3500HD 4x4
2012 GMC Sierra 3500HD 4x4
thespymaster is offline   Reply With Quote
Old 03-16-2014, 01:47 PM   #2
Vangres
Timed Rage
Vangres's Avatar
Drives: Mercedes Benz 300 C sport
Hey Spy,
I had this happen to me before, I think I have similar engine mods as your car, I got this twice on the same day, but the reason was obvious, it was from me, I basically turned on the ignition while the car software was updating from one of the LS1 program files Andy from Livernois sent me, and the car could not start afterwords. The car was parked, I didn't get it while driving. I just left the car, came next day and it started like nothing had happened, at that time I did the correct procedure to update the engine software, and didn't have problems after that.
The messages I got was : Engine power reduced, service stability track, and power steering.
Vangres is offline   Reply With Quote
Old 03-16-2014, 07:54 PM   #3
ZO6 Bryan
ZO6 Bryan's Avatar
Drives: 02 Z06, 95 Trans Am, 2012 ZL1
Need to start with the list of codes set. Post them up and that would be a start. Several things can cause REP. And what are your mods. If you've done a pulley and whoever tuned it missed a particular diagnostic test that needs adjustment you will get REP
Bryan 2018 ZL1 M6
ZO6 Bryan is offline   Reply With Quote
Old 03-16-2014, 08:01 PM   #4
ZZZL1
ZZZL1
ZZZL1's Avatar
Drives: 2013 ZL1 M6
I got the same thing twice after hard acceleration before the car was completely warmed up. Car felt like it was running on 2 cylinders. I have the JDP700 package and my tuner said it was MAF scaling error in my tune and he corrected it immediately. No problems since.
ZZZL1 is offline   Reply With Quote
Old 03-16-2014, 09:31 PM   #5
ZO6 Bryan
ZO6 Bryan's Avatar
You probably set P0101 and P0068 codes. Easily fixed in the tune.
Bryan 2018 ZL1 M6
Old 03-16-2014, 09:44 PM   #6
thespymaster
That's exactly how the car felt like after I tried to re-start it and then I just shut it down and had it towed
Chevy dealer will give me the answers & codes on Monday and I'll post up ASAP
Thanks for ALL the replys
2013 Camaro SS
Old 03-16-2014, 10:15 PM   #7
ZO6 Bryan
ZO6 Bryan's Avatar
I have cleared those codes driving down the highway with the laptop in the passenger seat. Reset the codes and REP gone and it runs right again. Didn't even need to stop the car.
Bryan 2018 ZL1 M6
Old 03-16-2014, 10:44 PM   #8
Vroom
Drives: 2013 Camaro ZL1
I had a bad accelerator pedal sensor cause it. It would trigger randomly and we annoying as hell.
  • 2013 Victory Red ZL1 - 210K+ miles. Mods: Who needs mods...its a freaking ZL1 - Last car: 2006 GTO
Vroom is offline   Reply With Quote
Old 03-17-2014, 07:07 PM   #9
thespymaster
Dealership just called and said it that it's a wirng issue tied to the Cam sensor ?
They are trying to source if wiring to that sensor is bad or the sensor itself is bad!
2013 Camaro SS
