Old 08-25-2013, 05:57 PM   #1
thespymaster
thespymaster's Avatar
Drives: C7 / ZL1 / SS / trucsk
FACTORY TIE DOWN POINTS ?
Where are the the actual FACTORY tie down points on the ZL1?
Any assistance would be appreciated
I don't want to have to strap though the wheels
thespymaster is offline   Reply With Quote
Old 08-25-2013, 06:27 PM   #2
Gtkilrss
Gtkilrss's Avatar
Drives: 2016 SS
Be interesting to know. If I crawled under my car I could remember where I tie it down at. But be nice to know the designed tie down points!
Gtkilrss is offline   Reply With Quote
Old 08-25-2013, 07:05 PM   #3
tpower
DBLCHBY III
tpower's Avatar
Drives: 15 1LE
try posting this in the drag race section
tpower is offline   Reply With Quote
Old 08-25-2013, 07:14 PM   #4
flyinglow57
Drives: rumble bee,2SS 6sp
As a tow driver 95% of the gm cars have them just inside the pinch welds behind the front wheels and infront of the rear tires. Kinda where you would jack a car up...
blk 2ss 6spd with sunroof.
intake,tsp cam,full exhaust,pcmforless tune,trailing arms,toe rods. hopeing for 11.9 because my g/f said she will take the cam and the suspension back if not.
flyinglow57 is offline   Reply With Quote
Old 08-25-2013, 08:05 PM   #5
gmgdave
gmgdave's Avatar
Drives: 12 ZL1 & 08 Suzuki Boulevard C50
no factory tie down points. I am installing universal tie downs from RENNLINE since my ZL1 is on a lift I have a found a few places to install and the 66 degree ones do not hang down.
2012 ZL1 - #413 - IOM - Mods; Exhaust Commander. GMG Third Brake Light Pulsar, Tinted Windows, color matched Engine cover, ZL1 Floor Mats
gmgdave is offline   Reply With Quote
Old 08-25-2013, 11:00 PM   #6
thespymaster
You would think someone underneath is a good connection point
Old 08-27-2013, 10:23 AM   #7
THR ZL1 #1
Perma Grinning
Drives: 2012 Tom Henry Racing ZL1
Here is a pic of the frame tie down locations I use.
The rear locations are easy to find, in front of the tires about in line with the jack pad notches on the side rails.
The front locations on a ZL1 take a bit of work. take out about 4 - 5 of the bolts on either side of the belly pan so that it is loose enough to pull down so that you can find the factory hole in the frame rail. Locate the hole on the belly pan, and use a Dremel with a roto cutting tool and route out the hole using the factory frame rail hole as your guide.
THR ZL1 #1 is offline   Reply With Quote
Old 08-27-2013, 10:25 AM   #8
THR ZL1 #1
Perma Grinning
Originally Posted by gmgdave View Post
no factory tie down points. . . .
Sorry yes they do . . just like every other car on the road.
I have never found a GM car that did not have elongated holes in the frame to utilize "T" hook it.
I've done, my 4th gens, my ZL1, my HHR, my GTO . . .
Old 08-27-2013, 10:28 AM   #9
THR ZL1 #1
Perma Grinning
Here is a close up of the hole in the front rail with the hole cut in the belly pan.
Old 08-15-2020, 05:25 PM   #10
KalCorp
Space Coast Camaros
KalCorp's Avatar
Drives: 2012 Camaro Vert
Anyone know if the back tie down locations can be used on a convertible?
There is a extra bracing bar that is almost over the hole.
Dont know if a t hook will still fit.
KalCorp is offline   Reply With Quote
Old 08-16-2020, 02:12 PM   #11
Vegas Bound
Drives: 2013 Sparkly Red One
I use one of these 6 holes, the thickest one. I have to put the straps in before pulling the car in the trailer. I use the LSAs in the rear. I have towed thousands of miles like this. No bounce, no movement in the trailer.
