10-30-2013, 10:14 PM | #1 |
Drives: C7 / ZL1 / SS / trucsk Join Date: Nov 2009
ADVICED NEEDED - SOMETHING IS SUCKING POWER AFTER ORACLE INSTALLED LIGHTS!
Let me start with after my 3 week tour of the USA, I stopped off at Oracle (AAC) store in Houston for some light upgrades to my ZL1.
Oracle installed: > Halos > Dual Scanner light > Footweel lights > underbody lights > wifi controller to control halos and underbody lights It took them a week to install, and prior to the isntallation had no power / battery related issues period. So we departed back to Arizona and along the way, we stopped about 400 miles to check all the ratchet straps , and sure enough the lights were ON in the trailer that Oracle installed. No they were left on from departure, everthing off! So another 350 miles and we stop to check ratchet straps again, and sure enough the ORACLE lights were back on again !! When I arrive at my destination , to start the ZL1, the battery is dead, and needed to jump start it! Put a brand new battery in the car. Overnight battery dead again CLUES?
2014 C7 Stingray 3LT/Z51
2013 Camaro SS 2012 Camaro ZL1 - 850 HP 2015 GMC Denali 3500HD 4x4 2012 GMC Sierra 3500HD 4x4 |
10-30-2013, 11:03 PM | #2 |
Drives: Camaro Join Date: Sep 2013
What was there justification for taking a week? Can I ask how many hours of labor you paid for?
Is the wifi connecting via on star? |
10-30-2013, 11:50 PM | #3 | |
They actually worked on the car 7 working days and only installed the above products.. They had other vehicles as well that they were working on . Price wasn't the issue, got great price from Oracle/AAC....
10-31-2013, 12:06 AM | #4 |
FYI, my email commuication with AAC
On Mon, Oct 28, 2013 at 3:10 PM, Justin- Advanced Automotive Concepts <> wrote: Nothing can draw power without being on (illuminated) are you saying the lights are coming on and draining the battery? On Mon, Oct 28, 2013 at 3:11 PM, Kelly Fromm <> wrote: Justin When I left HOUSTON, and made my first check of ZL1 in trailer after 300+ miles, the lights were on the car (scanner) and underglow next stop, same thing, lights on and then didnt make another stop until I got to cali 600 miles and battery was dead on arrival On Mon, Oct 28, 2013 at 3:11 PM, Kelly Fromm <> wrote: i have that wifi device that was installed, is that thing sucking power waiting for commands? On Mon, Oct 28, 2013 at 3:19 PM, Justin- Advanced Automotive Concepts <> wrote: Not as long as you are powering it down when not in use (there is a power button on the top of the remote) On Mon, Oct 28, 2013 at 3:28 PM, Kelly Fromm <> wrote: You mean the WHITE REMOTE ? Thats what I used to turn off the lights.... But assume you can also do it from CELLPHONE, so wouldnt it always be on then? I used just the WHITE REMOTE to turn it off! On Mon, Oct 28, 2013 at 5:44 PM, Justin- Advanced Automotive Concepts <> wrote: Right, if you switch it off with the white remote it no longer has a power draw.
10-31-2013, 09:33 AM | #5 | |
So how is this connection occurring? Wifi and Internet are one and the same. |
10-31-2013, 09:50 AM | #6 |
Drives: 2011 Synergy Green Camaro LT Join Date: Jul 2011
Is the app running in the background on your phone? Or maybe the remote is bouncing around and turning the lights on? Its definitely going dead bc they are turning on. Stand by mode for the wifi has an extremely low amp draw so its not that. Could be a lose power or ground bc generally when u disconnect the controller boxes and connect them back their first function is "on". So it might be losing connection and then when it reconnects the lights are illuminated.
And wifi does not = internet. Wifi is just a an electronic connection to send information from 1 device to another. Doesnt mean it connects to the internet |
10-31-2013, 10:06 PM | #7 |
Car was just at Loud Pedal Motorsports trying to find the source of POWER sucker and they also reported issues with Knight Rider lights from Oracle..
Loud Pedal found the wifi interface as wired by Oracle and put a kill switch , to shut off the power completely when not is use..... And next day, battery did again!! They "Loud Pedal" didnt have enough time to check everything as i had to load up for SEMA.... But pic is below was taken at Oracle the day they finished
10-31-2013, 10:36 PM | #8 |
The manufacturer of the Forgiato grille, informed me tonight that he had to undergo rigorous testing for the electronics portion of the grille as not to exceed a certain load on the electrical system of the camaro......... He's thinking that the Oracle crew who installed the lights, specifically the KNIGHT RIDER light, MIGHT have been tied into the wiring harness of the Forigato grille as a shortcut vs Oracle running their own connection and most likely the culprit of the problem.
I won't know any more until after SEMA............ran out of time.... But the WARNING is this, whomever the installer is you chose, make sure they are home running their own wires (power/ground) from point A to point B vs just splicing into existing wiring as the LOAD on the electronics of the camaro has is very precise!!!
11-01-2013, 10:55 AM | #9 |
Your car is looking great. Wish i could go to SEMA this year. Im starting to turn away from oracle products lately. The past 2 or 3 halo kits ive gotten have had leds out on them and the back order time is ridiculous. Not impressed at all lately. And the warranty is great but not when I have to redo a customers lights on my time, $ and labor without compensation
11-01-2013, 11:17 AM | #10 |
instigator
Drives: 2020 6.2 Trail Boss, 2022 XC90 Join Date: Jan 2010
yeah...someone short cutted you man.
If nothing else, kill constant power to the lights. use accessory only. Or, break the power lead for the constant and buy a switch of proper amprege so you can toggle it on or off to physically break the circuit.
-John S.
11-01-2013, 10:26 PM | #11 | ||
I will be having a complete inspection after SEMA by a company called NSA Electronics in Arizona that specializes in troubleshooting/fixing these type issues! Kelly
