BeckyD @ James Martin Chevy
Old 02-11-2016, 09:50 PM   #1
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
Anyone have experience with the E-DIFF?
Curious if anybody has driven a car with it and can explain features and benefits better than Google lol?
Old 02-11-2016, 09:54 PM   #2
The1DoubleN
Drives: Blown up '16 SS
I can't explain anything but the LSD on this car means business in the canyons roads, you can feel it straighten out the car when gassing it out of a corner, like AWD for the real axel only :-). It works well and seamlessly. I will say however it does not seem to like the 4 floor windy ramp up my office parking garage, feels like it's fighting to keep the wheels at the same speed since the ramp is so tightly wound and made of uneven pavement.
The1DoubleN is offline   Reply With Quote
Old 02-11-2016, 09:55 PM   #3
Eric SS
#becauseracecar
Eric SS's Avatar
Drives: 2016 SS Sedan, 2016 Camaro SS
You don't have an e-diff if you are talking about the car in your profile.
Eric SS is offline   Reply With Quote
Old 02-11-2016, 10:37 PM   #4
mcsoul
Drives: Want a gen 6
A smart electronic limited-slip differential (eLSD) is included in the Z51 Performance Package and continuously makes the most of the torque split between the rear wheels. The system features a hydraulically actuated clutch that can infinitely vary clutch engagement and can respond from open to full engagement in tenths of a second. It shifts torque based on a unique algorithm which factors in vehicle speed, steering input and throttle position to improve steering feel, handling balance and traction.
The eLSD is fully integrated with StabiliTrak and Performance Traction Management systems. Its calibrations vary among three modes, based on the Drive Mode Selector setting:
Mode 1 is the default setting for normal driving and emphasizes vehicle stability
Mode 2 is engaged when electronic stability control is turned off in the Sport or Track Driver Modes. This calibration enables more nimble turn-in and traction while accelerating out of a corner
Mode 3 is automatically selected when Performance Traction Management is engaged. This calibration has the same function as Mode 2, but is fine-tuned to work with Performance Traction Management.
Read more: http://www.corvetteforum.com/forums/...#ixzz3zvPwhrSE
mcsoul is offline   Reply With Quote
Old 02-11-2016, 10:40 PM   #5
The1DoubleN
My bad. At any rate the LSD on the current SS is great, and i've had electronic difs on BMW's that didn't seem to respond as quickly.....
Old 02-11-2016, 10:55 PM   #6
sycraft
COTW 5/06/2013
sycraft's Avatar
Drives: 2017 Corvette Grand Sport-Ho-Vette
on my vette it tracks great , very predictable, not sure how to explain it, but it puts the power to the pavement
2017 Grand Sport, Borla X Pipe.....Enough Said
sycraft is offline   Reply With Quote
Old 02-12-2016, 01:23 AM   #7
JeffInDFW
Camaro owner for 29 years
JeffInDFW's Avatar
Drives: 96 Viper GTS/09 Sky Redline/95 Z28
I have driven a new Z51 Corvette with the new Electronic Limited Slip Diff (eLSD) on track, and it is game changing technology IMO.
To explain it in very simplified term, it is usually best to exaggerate both extremes. If you have a completely OPEN differential, the car is easy to rotate (or turn) in a corner. If you have a LOCKED rear differential, it is easy to put down power because both rear tires are spinning at the exact same speed, but the car will only go straight. The eLSD that GM developed in house uses ALL of the information brought in by the stability control system, the AMAZING Performance Traction Management system (best in the business IMO), yaw sensors, throttle sensor, tire temperature, etc etc etc, then uses an electronically controlled clutch inside the rear diff which can switch between FULL OPEN and FULLY LOCKED (and everything in between) in fractions of a second. So, the car is able to infinitely vary the amount of "rotate" the rear end has at every single moment of the corner. That is MY understanding of how it works. What I can tell you first hand is, it does work. It almost feels like there is a hand of God back there tidying up my racing line. When I am expecting the car to understeer or oversteer, it somehow does not happen. I think this is why GM was able to put such a narrow tire on the C7 Z51, add 250 pounds of weight and remove 45 horsepower and have it lap very close to the C6 Z06.
AND GM HAS PUT THIS PIECE OF MAGIC IN THE NEW 1LE. You guys who take your car onto a track/autocross will love it.
JeffInDFW is offline   Reply With Quote
Old 02-12-2016, 04:03 AM   #8
Brian 1LE SS
Drives: 98 Camaro SS
I wonder how well it will hold up under the strain of some sticky Hoosiers.
98 Camaro SS M6, a few mods
13 Ram R/T, tow vehicle
6th gen??
<a href=http://www.norcal-lsx.com/multimedia/data/500/562752_4054654816027_115782456_n.jpg target=_blank>http://www.norcal-lsx.com/multimedia...15782456_n.jpg</a>
Brian 1LE SS is offline   Reply With Quote
Old 02-12-2016, 06:59 AM   #9
GretchenGotGrowl
GretchenGotGrowl's Avatar
Drives: 11 F150 EB/13 Sonic RS/15 Z06
This pretty much sums it up. On the street you will mostly notice it helping with stability. On the tracks, you can come on the power a bit quicker as you unwind the steering. It REALLY helps in the fast S curves as the weight is shift from one side to another.
Question, and I apologize if this is in one of the many 1LE posts (haven't had time to go through them all), but does the 6th gen have the DIC screen to show you how the torque vectoring is applied? The C7 has a screen that shows % between the two wheels, but it would be nice if it had imaginary lines for predicted angle. I think that would help refine your turn in points.
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread
GretchenGotGrowl is offline   Reply With Quote
Old 02-12-2016, 07:43 AM   #10
Eric SS
#becauseracecar
Eric SS's Avatar
Yeah, the e-diff on BMW's is crap. From the info above, it sounds like this is a true LSD that is electronically controlled. The "e-diff" on BMW's non-M cars is basically an open diff and the car can apply one rear brake to keep it from slipping. It's total garbage. I like how the GM one sounds though!!
Old 02-12-2016, 07:58 AM   #11
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
Sounds very interesting...seems like it may even help at the drag strip too.
Old 02-12-2016, 08:04 AM   #12
sycraft
COTW 5/06/2013
sycraft's Avatar
The 1 le is a track car.. not a drag car.. i would mod a auto ss for that
Sent from my SM-N920P using Tapatalk
Old 02-12-2016, 08:11 AM   #13
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
Oh, I'm well aware. I was making a statement...as I do autocross and drag race, so it may help there too. I did the same with my C5 Z06...for 10 years.
Old 02-12-2016, 08:13 AM   #14
Boilermaker128
Drives: 2010 CobaltSSTC
Tire temperature? Are you sure mate? Is there an actual heat sensor in your wheels or is it a best guess from outside temp+other factors?
Boilermaker128 is offline   Reply With Quote
