10-30-2017, 01:47 PM | #1 |
マスタング = 遅い
Drives: 2017 Chevrolet Camaro SS 1LE Join Date: Aug 2015
2018 GT PP A10 dyno 415/397.
According to Late Model Muscle. I know, dynos are just tuning tools, but...meh. Most LT1's dyno about the same HP, and beat that TQ number.
My buddy just did his '17 SS 1LE, dynojet, SAE corrected, 420/419. Last edited by SS 1LE; 10-30-2017 at 01:57 PM. |
10-30-2017, 01:53 PM | #2 |
Drives: 14 Silverado LTZ Z71, 16 Camaro SS Join Date: Nov 2009
It’s an auto.
Around 410-415 is on the high side for an a8 SS. It’s doing about what it should. Also depends on the gear they dyno in. Most a8 cars will reach 400+ if they can be dyno in 6th gear. Some dyno won’t allot that much speed. 5th makes them about 20 RW lower |
10-30-2017, 01:56 PM | #3 | |
1LE enthusiast
Drives: 2017 SS 1LE Join Date: Mar 2017
Either way, HP seems to be about the same as the LT1...considering they rate it 5 higher. But the LT1 has it on TQ...
2017 SS 1LE
10-30-2017, 01:59 PM | #4 |
A8 is seeing lower losses than historically too. Only about 10-15 less than the m6 same dyno if the a8 is in 6th. I believe Ted from Jannetty gets 410-415 RW on autos and 425-430 manual
10-30-2017, 02:02 PM | #5 |
マスタング = 遅い
Wow, he's getting 430 out of stock M6 LT1's? I haven't seen (personally) higher than 422...
10-30-2017, 02:21 PM | #6 | |
http://www.camaro6.com/forums/showthread.php?t=472259 Highest I’ve heard of is 431. By Hennessey IIRC |
10-30-2017, 02:39 PM | #7 | |
マスタング = 遅い
10-30-2017, 05:17 PM | #8 |
Drives: '16 2SS / '05 SRT10 Ram / '65 bu Join Date: Dec 2015
When I see dem wide-eyed cocky Blue oval boys next year at Atco, all I will be thinkin is
. Fresh meat
H/C SBE 9.80@140 powered by Texas Speed
10-30-2017, 05:33 PM | #9 |
Drives: 2021 LT1 10 speed auto Join Date: May 2013
The Camaro does better than the average LT1 C7, they typically dyno at 400 to 410 with a manual. If you figure 15% loss thru the drive train, that is where it should be 460 and 470 on the high side.
