Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Camaro V6 LFX Engine, Exhaust, and Bolt-Ons
Old 02-29-2016, 08:13 PM   #1
Jason@JacFab
Drives: 2016 1LT RS Camaro; 72 Chevelle
Send a message via AIM to Jason@JacFab Send a message via MSN to Jason@JacFab
Howto retain your engine cover after installing the JacFab Extendolator Intak...
I've been getting asked this a lot so I figured I would post this here and explain what is needed to retain your engine cover after the intake manifold spacer is installed.
When you receive the intake spacer, in the hardware bag there will be a small aluminum spacer with a button head bolt and washer screwed into the end. Remove the engine cover stud from the bracket at the pass. side front of the engine. Screw the stud into the spacer, then secure the spacer/stud assemble into the bracket with the supplied bolt and serrated lock washer. It should all look like the picture below:
The stud height issue is now taken care of.
To take care of the oil cap/filler height issue, you will need to order GM part number 92068813 (described as "TUBE"). It is an oil filler extension and cap from a 2008-2009 Pontiac G8 w/ a 3.6l v6 engine (NOT the v8 engine part)... It's about an $8-9 dollar part you can order at your local GM dealer, or pick it up online.
When you receive that, you can either use the oil cap that comes with it, or use your old one, that's up to you. Screw the extension into the elbow oil filler on the driver's side front of the engine. The tube extension kind of snaps, and locks onto the original, once it's installed it will be VERY DIFFICULT (Impossible?) to remove, so be warned.
Install oil cap and you're done.
That said, if you're going for all out max performance, I recommend running without the engine cover anyway. All it does is just keep the heat from escaping the intake quickly and acts as an insulator. But I suppose you can put it on for car shows, etc this way...
Jason@JacFab is offline   Reply With Quote
Old 02-29-2016, 08:46 PM   #2
Shawno72
Shawno72's Avatar
Drives: 2015 Black 2LT RS M6
Great news. I like fact that I know have that option. Thanks Jason!
Overkill tune/E85/80mm•CAI cold air intake w/my custom maf tube•Apex air scoop•JacFab ported intake/Extendolater•Vitesse•EE EX2 catch can•Innovate wideband•ARH HFC's•NPP exhaust•11386 xpipe•Brembos/cross drilled/slotted rotors•SS M/C•Pfadt 1.25 springs•1LE struts/sways/strut tower brace•BMR diff bush, trail arms/bush, adj toe links•My custom Tunnel brace•Hurst short throw shifter•JDP stage 1 clutch res•1LE steering wheel, shift boot•ZL1 rear diffuser/splash guards•GM splitter•Z/28 grille/flowtie/spoiler/wheels•GM performance pedals•"Chevrolet" door sills•10" Kicker sub•BigWorm overlays
Shawno72 is offline   Reply With Quote
Old 03-01-2016, 04:38 AM   #3
chasmanian
chasmanian's Avatar
Drives: 2015 Camaro SS
Great post Jason. Thanks!
chasmanian is offline   Reply With Quote
Old 03-01-2016, 05:27 AM   #4
45thCamaro
45thCamaro's Avatar
Drives: 2012 Camaro 45th Anniversary RS
I did this maybe last year or ever earlier, Jason gave me the info back then as well. Just a heads up, make sure that your part number is exact. When I went to buy mine from the dealer, the guy ordered me the same part named "Tube" but it was from the v8 G8. Have to make sure. The best way of knowing is the the v6 part is a straight piece where as the v8 is like a 45° turn. Hope this helps!
45thCamaro is offline   Reply With Quote
Old 03-01-2016, 09:45 AM   #5
Jason@JacFab
Originally Posted by 45thCamaro View Post
The best way of knowing is the the v8 part is a straight piece where as the v6 is like a 90° turn. Hope this helps!
I think you have that backwards?
The v6 piece that you buy is straight (but the piece you put it into on the camaro is like a 90 deg turn.)
The v8 one is bent.
So if anyone gets the one on the right in the picture above tell the parts person it's wrong, it's for the v8, and you need the v6 one.
2008-2009 Pontiac G8, 3.6l v6
Part number 92068813
Old 03-01-2016, 11:20 AM   #6
45thCamaro
45thCamaro's Avatar
I'll fix my post. It was so long ago, good catch.
Old 03-03-2016, 02:14 PM   #7
Shawno72
Shawno72's Avatar
Anyone looking to buy this tube look here, was only $8.61 to my door.
http://www.gmwholesaledirect.com/oe-gm/92068813
Old 03-03-2016, 04:48 PM   #8
Tortugas12
Tortugas12's Avatar
Thank you! $8.31 shipped for me
Tortugas12 is offline   Reply With Quote
Old 03-03-2016, 04:52 PM   #9
Shawno72
Shawno72's Avatar
Glad to help. Not to often we a mod for under $10 haha
Old 03-09-2016, 07:58 AM   #10
Shawno72
Shawno72's Avatar
Just for reference here is a shot of the engine cover on with the oil tube extender.
Old 12-05-2018, 05:56 PM   #11
Jason@JacFab
Getting a lot of people asking me about this lately, so I figured I'd give it a bump for all the new eyes to see that aren't familiar.
Old 12-05-2018, 07:46 PM   #12
45thCamaro
45thCamaro's Avatar
Hey Jason, haven’t really been here in a while. Still have my camaro with the extendolator on it. Don’t drive it much but no issues. Hope all is well on your end, merry Christmas bud
extendolator, intake manifold, jacfab, spacer
