06-27-2012, 12:16 PM | #1 |
Drives: '12 AGM ZL1 (SOLD); '07 Ducati 1098 Join Date: Oct 2011
Quick Question for Drag Racers (MANUAL ZL1)
I'm curious if when doing a burnout in a manual transmission ZL1 (to heat up the tires before a drag race) you are supposed to turn off just TC (by hitting the TC button once) or do you guys also turn off Stabilitrack as well? (by pressing & holding the TC button).
It seems to me that you would just turn off TC as Stabilitrack only kicks in when the vehicle is in motion and going around a turn... |
06-27-2012, 12:52 PM | #2 |
Drives: 2013 ZL1 #142 Join Date: Feb 2012
I'd like to know this as well!!
Order # QHQWJF
Current Status: 4200 VIN 142 1100, (04/25/12): 2000, (05/21/12): 2500, (5/22/12): 3000, (5/22/12): 3100, (5/31/12): 3300, (5/31/12): 3400, (6/7/2012): 3800, (6/15/2012): 4000, (6/15/2012): 4104, (6/15/2012): 4106, (6/19/2012): 4150, (6/19/2012), 4200, (7/16/2012), 4300, (7/18/2012), 4B00, (6/15/2012) , 5000, (7/25/2012) 6000, Delivered to the customer (8/2/2012) |
06-27-2012, 12:55 PM | #3 |
Drives: 2012 ZL1 IOM#1645 Join Date: Mar 2012
Me also
06-27-2012, 01:02 PM | #4 |
NuptualNemesis
Drives: Silver 1SS M6 - 480hp 11.57/120.79 Join Date: Jul 2009
I turn everything off on my M6.
You should always turn TC off on the street for hard shifting. I sheared drive shaft bolts, and pulverized a rear end, and chipped a ring gear due to TC. You do not want brakes applied when shifting, harder they spin the harder the brake is applied. Stability control is good for the street. If you get sideways, just lift and it will straighten you out. Go to this link for good racing tips. http://www.camaro5.com/forums/showth...t=62548&page=2 |
06-27-2012, 01:02 PM | #5 |
Drives: 2017 ZL1 A10 Join Date: Sep 2009
I just turn off TC.
Also, if you are going to use launch control don't sidestep the clutch. Lift your foot off. After some testing I found that side stepping the clutch causes too much wheelspin. "Stock car and tires"
2017 ZL1
A10 Redhot with stripe |
06-27-2012, 01:09 PM | #6 |
Drives: '81-Z28/'07-Tundra/'12-ZL1/'13-Jeep Join Date: Oct 2011
+1 on the no side stepping for sure and the single press for TC disable works fine for standing burnouts.
ZL1 #612
06-27-2012, 03:38 PM | #7 |
06-27-2012, 04:46 PM | #8 |
I saw this guy on the Corvette forums alot when I had my C6...he runs very consistent and fast 1/4 mile times on a stock Z06 and has some useful tips:
http://rangeracceleration.com/ |
