Old 06-23-2018, 01:50 PM   #155
fastball
Drives: 2017 Camaro 2SS 6MT
Also depends on how big your boat is or how rough the road is to the cabin. If you've just got a little 16 footer or something, you shouldn't have a problem towing it with the V6. And if that mountain cabin is on a half decent dirt road, again you'll be fine.
Now, if your boat is a twin V8 powerboat at 30' long & you plan on taking it and your family (with all your stuff) 100 miles every other weekend, I wouldn't recommend using any Blazer from any year. Or if that cabin isn't even on anything that could be considered a trail, tip toeing between boulders and trees for 10 miles, you're going to want to at least put a bit of money into upgrading your old Blazer because its probably outmatched as a stocker with some mud terrain tires.
On the other hand, if like the overwhelming majority of people who own a utility of some sort you don't do anything like that ... this Blazer is the best one ever built.
The old K5 Blazer/Tahoe (1969-99) could be equipped with either the standard 350, a 6.2 Diesel, or a 454 gas. Depending on model year. It was quite possible to get one equipped to tow up to 7500 lbs.
Now, the S-10 Blazer, 1982-2005, was the one that was never meant to tow much since it’s engines were either a 4 banger or a 2.8-4.3 V6.
The K5 Blazer/Tahoe was and still is the best Blazer ever built. Better than this new piece of front wheel drive-based plastic.
To paraphrarse Doc in Back To The Future Part II:
“Marty, he’s in a K5 Blazer, we’re in a 2019 Blazer. He’d cut through us like we were tin foil”
fastball is offline   Reply With Quote
Old 06-23-2018, 03:34 PM   #156
KMPrenger
KMPrenger's Avatar
Sorry, but some of you are way to hurt over this Blazer name thing.
So its not what your hopes and dreams were. You'll be OK. Promise.
This looks like a nice CUV. Period. It picks up where the last Blazer left off...a family car grocery getter...except much much better.
Old 06-23-2018, 03:51 PM   #157
fastball
I’m sure you’d say the same thing if the Camaro went front wheel drive.
Old 06-23-2018, 04:22 PM   #158
Drives: 2023 GMC Canyon, 2020 Colorado
2020 Chevrolet Colorado W/T Extended Cab (State-issued)
Old 06-23-2018, 04:45 PM   #159
h422694
h422694's Avatar
4,500 pounds (2,041 kg) estimated max trailering with the available 3.6L V-61.
I have a '14 Tacom 4x4 Off Road that has a towing capacity of 6400lbs. I've towed 4500lbs with it and it was fine but was still under max by almost 2000lb. I also had 2000 Blazer 4x4 with 4.3 V6 that was rated at 5600lbs. I pulled a 28' pontoon that weighed around 4000lbs. It would strain awful on the slight grades just west of KC. There are just too many variables - type trailer, type road, condition, hills, head winds and one a lot of people do not consider, outside temperature. Max weight towing and even slight uphill grade can easily overheat engine. Trying to tow 4500 with a vehicle rated 4500 would be an issue in my book regardless of vehicle.
h422694 is offline   Reply With Quote
Old 06-23-2018, 04:46 PM   #160
Royal Tiger
Again, where does this fit in? Is it between Trax & Equinox or Equinox & Traverse? Is there really that big a gap in either of those holes? That’s why I was hoping it was a smaller Tahoe.
Old 06-23-2018, 04:57 PM   #161
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
Its between the Equinox and the Traverse. Thats why they made the Equinox smaller and the Traverse bigger with the latest generation of each.
And the big boats that I mentioned, near as I can tell, are routinely in the 3 to 4 ton range by themselves. Then there is the trailer. Then you also have hundreds of pounds of payload in the truck itself between you, your family, and your stuff for the weekend. That weight takes away from the tongue weight capacity because you don't want to overload the rear end of your truck. I'm not even bothering with the recommended '85% safety factor' for towing.
Like I said, I would not recommend using ANY Blazer from ANY year for that kind of load.
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Old 06-23-2018, 05:23 PM   #162
fastball
Ok well your example sounds extreme and I don’t know anything about boats. My point is you can surely use a K5 to trailer much more than the S-10. So to suggest a K5 isn’t up to the task of serious hauling isn’t exactly accurate.
There’s serious trailering and then there’s extreme. Sounds like you need a 10,500 lb+ limit.
Your example sounds like it requires a Ford F-250 Super Duty duallie or Silverado 2500 Duramax Allison which is a whole different discussion.
Old 06-23-2018, 06:03 PM   #163
Scrappy Doo
Scrappy Doo's Avatar
Drives: Callaway Rogue
Interested to see pricing. Wife will need a new ride late this year.
I actually like it.
Although, I'd buy that 2 door Tahoe a few pages back tomorrow if I could find one. lol
Old 06-23-2018, 09:42 PM   #164
1Coopgt
1Coopgt's Avatar
Drives: All Black 2012 1LS
Originally Posted by hotlap View Post
The interior and RS front scream Camaro influences.
Attachment 942198
Looks like Chevy graphed a 2019 Camaro front end onto a Jeep Cherokee .
Mods, K&N CAI ,VTC , GM Perf Axleback Exhaust, Elite Eng CC and CSS, GM Strut Tower Brace,Carbon Fiber Anvil Spoiler,ASC T5 Splitter,Gen5diy Foglight kit.
1Coopgt is offline   Reply With Quote
Old 06-23-2018, 10:00 PM   #165
motorhead
Originally Posted by Stroked84 View Post
Those are just the DRLs? Interesting. This is the nicest looking Chevy vehicle since the Grand Sport/Z06. Camaro and Impala don't hold a candle to either. I just hope they don't price this thing too high.
The Corvette goes without saying. It's in its owm league. That's why i didnt bring it up.
Old 06-23-2018, 11:49 PM   #166
bobby35ny
bobby35ny's Avatar
Drives: 18 ZL1 A10
How original LOL!!
I got an Idea!! Lets remove 2 doors and call it a Camaro!
2017 ZL1 M6 Bog City, 2013 ZL1 M6, 2010 2SS M6
ZL1::J-E-T-S JETS JETS JETS
bobby35ny is offline   Reply With Quote
Old 06-24-2018, 01:14 AM   #167
hashtag
hashtag's Avatar
Drives: 2018 ZL1 A10/2018 GT350R #JR603
Looks like a ZL1 edition lol. I am going to make some $$$$$ on this. Build it GM.
2018GT350R+2018 ZL1 "Red Hot" A10 w/ PDR, Nav, Carbon Fiber Hood insert, Carbon Fiber Dash Insert, Carbon Fiber Fuel Dior & Sun Roof. T/M T-Body, Roto Fab & Borla S Type.
hashtag is offline   Reply With Quote
Old 06-24-2018, 02:08 AM   #168
SPARTAN sui
PC Technician
SPARTAN sui's Avatar
Drives: 2016 Hyper Blue 2SS
Why couldn’t the 2019 Camaro front end look that good?
SPARTAN sui is offline   Reply With Quote
