Old 09-08-2011, 06:53 PM   #1
Nightfall
"To Punish And Enslave"
Nightfall's Avatar
Drives: B E RS GBA #72541 3564 CC 220 CI
How Do You Reset TPMS?
got my new rims and tires on (get link to thread when updated). And they installed the sensors in my rims but i am still geting the warning light. I will have them check it tomorrow. But incase i can fix it myself how do i do it thanks
C.A.M.A.R.O- Constantly Adding Modifications Addiction Relentless Obsession
90% canadian 10% mexican 100% american muscle :flag2:
Nightfall is offline   Reply With Quote
Old 09-08-2011, 06:54 PM   #2
slick rick
SoCal Mayhem
slick rick's Avatar
Drives: 2010 Camaro 1SS/RS
Check the manual
The TPMS sensors can also be matched to each tire/wheel position by increasing or decreasing the tire’s air pressure. If increasing the tire’s air pressure, do not exceed the maximum inflation pressure indicated on the tire’s sidewall.
To decrease the tire’s air-pressure use the pointed end of the valve cap, a pencil-style air pressure gage, or a key.
You have two minutes to match the first tire/wheel position, and
five minutes overall, to match all four tire/wheel positions. If it takes longer than two minutes, to match the first tire and wheel, or more than five minutes to match all four tire and wheel positions, the matching process stops and you need to
start over.
The TPMS matching process is outlined below:
1. Set the parking brake.
2. Turn the ignition switch to ON/RUN with the engine off.
3. Go to the TPM vehicle information screen on the DIC. See Driver Information Center (DIC) on page 4-27. Press set to relearn the sensors. The horn sounds twice to signal the receiver is in relearn mode and Tire Learning Active message displays on the DIC screen.
4. Start with the driver side front tire.
5. Remove the valve cap from
the valve stem. Activate the TPMS sensor by increasing or decreasing the tire’s air pressure for 10 seconds, or until a horn chirp sounds. The horn chirp, which can take up to 30 seconds to sound, confirms that the TPMS sensor identification code has been matched to this tire position.
6. Proceed to the passenger side front tire, and repeat the procedure in Step 5.
7. Proceed to the passenger side rear tire, and repeat the procedure in Step 5.
8. Proceed to the driver side rear tire, and repeat the procedure in Step 5.
9. After hearing the confirming horn chirp, for the driver side rear tire, the horn sounds two more times to signal the tire learning mode is no longer active. Turn the ignition switch to LOCK/OFF.
10. Set all four tires to the recommended air pressure level as indicated on the tire and loading information label.
11. Put the valve caps back on the valve stems.
slick rick is offline   Reply With Quote
Old 09-08-2011, 06:58 PM   #3
HDRDTD
If you have a 2011, you have to take the car to the dealer to have th enew TPMS calibrated to the car. It takes a special hand held device to do it.
BTDT when I bought my new rims/tires.
You CANNOT do it the old fashioned way by changing the tire pressure at each wheel one at a time like you used to be able to do.
The good news is my dealer told me that any time I want to change my wheels, just bring it in and they'll re-calibrate the TPMS sensors for free. It only takes a few min.
Old 09-08-2011, 06:58 PM   #4
HDRDTD
Originally Posted by slick rick View Post
Check the manual
This procedure will not work on the 2011's.
Old 09-08-2011, 07:01 PM   #5
slick rick
SoCal Mayhem
slick rick's Avatar
Bummer :(
Old 09-08-2011, 07:09 PM   #6
Nightfall
Nightfall's Avatar
good to know thanks ever one for the help i will see if they can do it if not to the dealer i go!
Old 09-08-2011, 07:55 PM   #7
Dogditcher
Dogditcher's Avatar
Drives: 2011-1LT RS COUPE
2011 manual says it can be done either way
TPMS Sensor Matching
Process
Each TPMS sensor has a unique
identification code. Any time you
replace one or more of the TPMS
sensors or rotate your vehicle's
tires, the identification codes need
to be matched to the new tire/
wheel position. Also, the TPMS
sensor matching process should
be performed after replacing a
spare tire with a road tire containing
the TPMS sensor in order for the
malfunction light and the DIC
message to go off at the next
ignition cycle. The sensors are
matched to the tire/wheel positions
in the following order: driver side
front tire, passenger side front tire,
driver side rear tire using a TPMS
diagnostic tool. See your dealer
for service.
tire's air pressure. If increasing the
tire's air pressure, do not exceed
indicated on the tire's sidewall.
To decrease the tire's air-pressure
gauge, or a key.
longer than two minutes to match
start over
Dogditcher is offline   Reply With Quote
Old 09-08-2011, 08:05 PM   #8
The Stig
knows 2 facts about ducks
The Stig's Avatar
No. It is in the manual. Pages 10-63 through 10-65. You use the exact same procedure as if the car was a 2010. Nothing changed.
Click to view my build thread
Old 09-08-2011, 08:21 PM   #9
justa25thTA
justa25thTA's Avatar
Drives: 2011 Camaro SS/RS LS3
Works on mine
Yeah, I'll get around to it...
justa25thTA is offline   Reply With Quote
Old 09-10-2011, 05:01 AM   #10
Nightfall
Nightfall's Avatar
UPDATE i went to a local dealer had him do it it was free of charge . Thank you ever one for your help
Old 09-16-2011, 08:08 PM   #11
Flashpoint135
Flashpoint135's Avatar
Drives: 2016 SS
The 2011 manuals were changed part way through 2011. Mine does NOT include the instructions about dropping tire pressure to reset - ONLY by using the relearn tool. If you check the online manual on the chevy web site it is the same:
http://www.chevrolet.com/assets/pdf/...aro_owners.pdf
What I would like to know is for cars after that change, from late in 2011, does the tire pressure change work anyway and is just not documented anymore, or did they really make a change to the system that stopped that option from working? I don't know how we will find out until one of us tries it.
HDRDTD - did you try it and it did not work? Sorry if that should have been clear to me already, I'm just trying to make sure I understand.
Flashpoint135 is offline   Reply With Quote
Old 03-19-2012, 06:56 PM   #12
TastyBake
TastyBake's Avatar
Drives: 2011 Camaro 2LT/RS Black
I got a 2011 and it worked on mine.
TastyBake is offline   Reply With Quote
Old 03-19-2012, 08:09 PM   #13
camaro_RS
Emerald Coast Camaros
camaro_RS's Avatar
Drives: A lot of show, not much go.
Wow, a Nightfall thread. Weird.
-White Mary Jane....build thread [COTW 6/11/12] :
camaro_RS is offline   Reply With Quote
Old 03-19-2012, 08:47 PM   #14
=Stephens=
=Stephens='s Avatar
Drives: 2011 LS
Hmmmmmm.....I really find it interesting how some think they know everything but they really don't.
I just put my 20's back on my car this weekend. And Reset my TPMS's on my 2011 by lowering the air pressure and they work great.
=Stephens= is offline   Reply With Quote
gm tpms reset tools cheap camaro1 Wheels and Tires Talk Sponsored by The Tire Rack 13 11-24-2017 02:32 PM
TPMS issues - finally a response! Nine Ball Wheels and Tires Talk Sponsored by The Tire Rack 157 04-17-2015 02:27 PM
Help!!! TPMS install onto TSW Nurburgrings Avalnch Wheels and Tires Talk Sponsored by The Tire Rack 13 03-09-2011 06:44 PM
Mounting OEM TPMS on 3-piece wheels Flux Wheels and Tires Talk Sponsored by The Tire Rack 12 03-07-2011 06:59 PM
What will a GM dealer exactly do when programming TPMS sensors on the car?Wont Reset! 55Designs Wheels and Tires Talk Sponsored by The Tire Rack 13 02-20-2011 08:02 PM
