11-22-2018, 08:57 AM | #1 |
Drives: 2010 RS Join Date: Sep 2018
random no start
2010 v6 rs wifes car. last week her car had trouble starting and replaces the battery because it was dead. all good until this week and car will sometimes not start. turn key nothing but a click sometimes others fires right up. turning key several times will get it to start. its not a voltage issue as everything works as it sould and starter speed is normal when it decides it wants to enguage.
11-22-2018, 12:48 PM | #2 |
Space Shuttle Aficionado
I'm assuming you replaced the battery with the same CCA as the previous?
If so, then it may be the starter solenoid.
12-23-2018, 12:06 PM | #3 |
Drives: looking Join Date: Sep 2017
More than likely starter. Mine is doing this exact same thing as of today. Definitely seems like every starter issue I've ever had.
Limited lifetime starter can be purchased for about $150. Just trying to figure out the exact starter position. Sent from my SM-G955U1 using Tapatalk |
12-23-2018, 04:46 PM | #4 |
376 cubic inches of fun
Either the starter is toast, or the starter ground wire is loose or has a corroded terminal.
