Vararam
Old 04-28-2017, 02:43 PM   #1
jdog1960
Drives: 2011 Camaro SS/RS Convertible
5th Gen Exhaust Cut Outs
any experience with these. best ones with remote?
jdog1960 is offline   Reply With Quote
Old 04-28-2017, 03:17 PM   #2
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
They all have the same basic operation, so purchase is based on budget.
Noweeds, Pypes, and QTP are the most common.
I personally run QTP on my ZL1 and have had zero issues for the four years I've run them.
SlingShot is offline   Reply With Quote
Old 04-28-2017, 07:44 PM   #3
Gunmetal Speedster
Gunmetal Speedster's Avatar
Drives: Savitar; The 500rwhp N/A Monster!
+1 on QTP. Don't have them but considered them at one point. Great brand it seems.
*SOLD*504HP/433TQ | Night Fury cammed • Cold Air Inductions intake • Bo White ported TB • Speed Engineering 1 7/8 longtubes • NPP catback • QTP low profile cutouts • Powerbond 25% UDP • 3.73 gears • JRE scoop • ZL1 grille • R1 Concepts drilled/slotted rotors • built/tuned by Weapon X Motorsports
Gunmetal Speedster is offline   Reply With Quote
Old 05-21-2017, 09:23 AM   #4
NJ20102SS
NJ20102SS's Avatar
Drives: 2010 Camaro 2SS/RS M6
I have the QTP's too, with the keychain remote. Love them!
Comp cam, Hooker Blackheart 1 7/8" SS long tube headers; titanium wrapped, CAI cold air intake, ARH high flow cats, Borla ATAK exhaust, QTP cut-outs with wireless remotes, Black Magic front and rear sway bars, Hurst shifter, 21" factory wheels, OEM ground effects, dyno-tuned by JP Superior Solutions.
NJ20102SS is offline   Reply With Quote
Old 05-21-2017, 10:17 AM   #5
Bowtie-Bri
Bowtie-Bri's Avatar
Drives: 2013 Camaro 2SS RS Convt.
I have the Noweeds elec. diverters and they are Awesome!
https://noweeds.net/collections/chevrolet-camaro
2013 Nickey Stage II Camaro SS Convertible #10.Black w/ Red leather interior. No Weeds Elec. Diverters, CNC ported heads, custom grind cam, upgraded fuel injectors, ZL-1 fuel pump, V-Max ported TB, Red Magnuson Super Charger with rear cog drive, upgraded rear axles good for 1400Hp, 3:45 gears, Tremec 6 spd., Pedders adj. coil overs, Phadt ZL-spec swaybars, 800Hp at the crank, 670RWHP, 613ft.lbs. torq. @ 11lbs. boost. SOLD!!!
Bowtie-Bri is offline   Reply With Quote
Old 05-21-2017, 05:55 PM   #6
Hurst
Camaros Of Northwest Ohio
Hurst's Avatar
Drives: 2013 SIM 2SS/RS, LS3
Just for reference...
Hurst is offline   Reply With Quote
Old 05-22-2017, 03:57 AM   #7
riozlander
that guy <--------
riozlander's Avatar
Drives: 2012 camaro V6 LS M6
^ <------ this post might want to be carful where you have them exit. side impact bags can be a little sensitive in these cars. funny video yup
but I have a v6 not much I can do for exhaust, without my car turning in to a loud buzz bomb/loud drone machine
riozlander is offline   Reply With Quote
Old 05-22-2017, 06:44 AM   #8
Glushenij
Glushenij's Avatar
Drives: 2014 Camaro 2SS 1LE
Qtp low profile, running them for 8 month not one single issue
AGP TT 807whp 811wtq 13.46psi E85+methanol
Glushenij is offline   Reply With Quote
Old 05-22-2017, 09:10 AM   #9
Superman09
Account SNAFU
Superman09's Avatar
Drives: 13 Tahoe 79 Scout II 15 1LE
Pypes and qtp are basically the same. They are a hole cut in the pipe with a butterfly valve to open and close the hole. NOWEEDS is completely different. It goes inline in the exhaust pipe and has 2 butterfly valves. That way when you open the NOWEEDS it closes off the rest of the exhaust and forces it all out the cutout. That's why Pypes and qtp are exhaust cutouts and NOWEEDS is a diverter.
Sent from my VS995 using Tapatalk
Superman09 is offline   Reply With Quote
Old 05-23-2017, 07:27 AM   #10
BAD DAB
BAD DAB's Avatar
Would the sound be as good if you still had stock catalytic converters?
