Vararam
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Regional Forums > USA - Florida
Old 04-12-2012, 07:05 AM   #1
BadFast29
Drives: 2012 Camaro RS
SQUEAK NOISE DRIVING ME NUTS!!!!
Hey guys, I have a 2012 RS and when driving for a few mins and going over uneven roads or slight bumps there is a squeaking noise coming from the drivers side on the inside, i've checked all the pannels and mad sure everything was snug and i cant figure it out.........and ideas??? please help!!!!
BadFast29 is offline   Reply With Quote
Old 04-12-2012, 07:14 AM   #2
Tampa Tuning
Drives: TAMPA TUNING FACEBOOK & INSTAGRAM
I had that problem once. I checked everything, and found my exhuast wasnt loud enough. Once I changed out to long tube headers and mufflers that woke up the neighbors, many of my car's problems got fixed........Including the piston slap common on the early LSx cars.
Tampa Tuning is offline   Reply With Quote
Old 04-12-2012, 08:45 AM   #3
avellanet.jr
Emerald Coast Camaros
Drives: 2014 ZL1 #77
I have it too! Still haven't found the cause.
avellanet.jr is offline   Reply With Quote
Old 04-12-2012, 09:12 AM   #4
tommy98z28
tommy98z28's Avatar
Drives: 2010 2ss
I had the same thing with my car but on a non stock exhaust..
There was a small bolt on the passenger side around the y rubbing against the exhaust. You wont notice it unless you actually look above the exhaust.
2010 2SS Bolt On's
98 z28 - in progress..
tommy98z28 is offline   Reply With Quote
Old 04-12-2012, 09:43 AM   #5
daveagogo1
TRI COUNTY TAMPA
daveagogo1's Avatar
Drives: 2011 1SS/RS VR/BLK A6
If drivers side inside check your speedometer bezel. When the noise starts place your hand directly on top of the dash above it and press down. See if it stops. Mine did this. I removed had it painted and replaced. No more noise.
This is the best way to find rattles and such inside car. Drive where you know it will make noise then press down on everything with some pressure and see if it stops repeat to verify. Now you pinpointed where the noise is.
To find exhaust rattles simply grab pipes and pull up and down or tap with a mallet to fins source of contact.
Originally Posted by HufferSS View Post
Fast cars have rubber on the quarter panels...you sissies need to knock it off.
daveagogo1 is offline   Reply With Quote
Old 04-12-2012, 10:25 AM   #6
stb3222
Drives: 2010 2SS
stb3222 is offline   Reply With Quote
Old 04-12-2012, 10:51 AM   #7
HIOFECR
HIOFECR's Avatar
Drives: Black 2010 Camaro 2SS
I just had the dealership do TSB 09-08-110-010 on mine for an inside vibration/squeak from the rear trim panel, is your squeak coming from the front or the back?
SQUEEZE THROTTLE. FEEL GROUND RUMBLE
HIOFECR is offline   Reply With Quote
Old 04-12-2012, 11:09 AM   #8
BadFast29
ITS HARD TO TELL I THINK FROM THE FRONT BUT IM NOT POSITIVE.
Old 04-12-2012, 11:35 AM   #9
Dylan88
UCF Knights
Dylan88's Avatar
Drives: 2012 2LT RS
Dylan88 is offline   Reply With Quote
Old 04-12-2012, 11:39 AM   #10
EWMAN
EWMAN's Avatar
Drives: 2011 2SS RS L99 Blk/Blk
I had the same thing on a 2011 2 SS RS, chased it for a month or so. back to the dealer a couple time, last time one of the technicians told me he had accidently put his hand on the overhead "console" and the noise stopped, so they took it apart, tightened everything up and I have had no squeak/rattles since... EVERYONE that listened for it swore it came from the middle of the dash towards the drivers side.
Just my 2 cents
EWMAN
Evil, Wick, Mean and Nasty
Aut Vinceri, Aut Mori
EWMAN is offline   Reply With Quote
Old 04-13-2012, 06:48 AM   #11
BadFast29
OK WELL I PUT MY HAND ON THE DASH AND OTHER SPOTS WHEN IT MAKES THE NOISE, THE NOISE DOES NOT CHANGE WHEN I DO THAT. ALSO IF I START TAPPING OR BANGING THE DASH AND TRIM IT DOES NOT MAKE THE NOISE, ALSO WHEN I GO OVER A SPEED BUMP THE NOISE ONLY COMES FROM THE FRONT ON THE INSIDE....IDK
Old 04-13-2012, 09:04 AM   #12
tommy98z28
tommy98z28's Avatar
Drives: 2010 2ss
Im telling you it could be the exhaust and a bolt... It happened to me over speed bumps if i slammed on my brakes or if i moved quickly.
2010 2SS Bolt On's
Old 04-13-2012, 10:05 AM   #13
The Blue Angel
The Blue Angel's Avatar
Drives: 2014 BRM 1SS/RS
Thread title reminds me of this part of a movie:
2014 Blue Ray Metallic 1SS/RS
A Road Warrior
The Blue Angel is offline   Reply With Quote
Old 05-04-2012, 01:12 PM   #14
BadFast29
So i finally found out that sqeak noise it was coming from the hood.
Clunking/clattering noise when pressing clutch - INFO HERE DarkObsession V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 20 12-30-2016 03:06 AM
Front End Knocking Noise Dave Sparkes Camaro Price | Ordering | Tracking | Dealers Discussions 4 04-14-2011 07:06 AM
OBXR Headers Installed Smoky10 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 44 12-17-2010 11:01 PM
How Many Camaro5 members does it take to change tighten spoiler nuts ffrcobra_65 5th Gen Camaro SS LS LT General Discussions 59 02-17-2010 06:31 AM
Ontario (Canada) Highway Traffic Act.. read so you dont lose your car sigma_1966 Canada 10 08-11-2009 05:51 PM
