Old 05-20-2018, 09:10 PM   #1
Provoste
Provoste's Avatar
Drives: E46 S54 race car, 964C2
Street/Track SS 1LE 19” Setup- Update
Hey guys- thought you guys might have interest in some new changes I’ve recently made. After last season, I decided I wanted to have my primary street/track setup be a square setup. I ran square slick setup last year and loved the adjustability tire-wise.
I ended up pulling the trigger on a set of Apex EC7 19x10.5 ET22 wheels mounted with 305/30 19 Hankook RS4’s. I wanted RS4’s for their longevity, I’ve seen in endurance racing (AER/WRL) how good their pace is vs a RE71R/ BFG Rival and how much longer they last, so I knew I wanted to try them on the Camaro.
I couldn’t be happier thus far, the rears poke similarly to the ZL1-1LE, and the fronts fit great.
Only mods needed are a 5mm front spacer, and the strut clearance grinding. Here’s a link to the strut mod: https://www.camaro6.com/forums/showthread.php?t=526353
No rubbing issues, full steering lock... no problem.
I’m at Mid Ohio with OVR PCA 6/8-10 then Watkins Glen over July 4/5 with Chin, should be a fun couple months!
Provoste is offline   Reply With Quote
Old 05-20-2018, 10:57 PM   #2
Roostie
all it takes is cash
Roostie's Avatar
Drives: 2018 LS V6 1LE; E350 wagon; Model3
Wow, looks perfect. Thanks for sharing your knowledge with the forum.
I'll be buying a square set of track wheels soon, and if I had an SS I might copy what you've done. But with a V6 1LE, I'll probably stick to 18" 275s or 285s.
Roostie is offline   Reply With Quote
Old 05-21-2018, 12:07 AM   #3
Ventura 1LE
Ventura 1LE's Avatar
Drives: 2018 SS 1LE
It does look good and in the long run.. cheeper when it comes to replacing the rubber 2x a year. I had the RS3s on my gen5 1LE until they quit making avail for 20 inches wheels I held onto the RS3s until the end. Hated to gotten rid of them.
If you dont mind sharing a ball park cost for your setup?
Also, any handling differences you may have noticed with car and possible changes in your shift points on the track.
Thanks for posting and pics..
Ventura 1LE is offline   Reply With Quote
Old 05-21-2018, 12:23 AM   #4
TrackClub
TrackClub's Avatar
Drives: 2020 SS 1LE (previous: 2017 SS 1LE)
Thx Provoste! Looking fwd to your laptimes at Mid O and the Glen Whats the initial feel of the RS4s vs RE71Rs?
Do they have much softer sidewall or not? Cheers!
TrackClub is offline   Reply With Quote
Old 05-21-2018, 07:04 AM   #5
mbar
Drives: 2016 1SS
Looks great !
Any spacers in the front?
1SS, Black, Black Wheels, A8, MRC, NPP
mbar is offline   Reply With Quote
Old 05-21-2018, 07:23 AM   #6
PolynesianPowerhouse
Big Samoan ina little car
PolynesianPowerhouse's Avatar
Drives: 2016 camaro
Love it! When you used the 5mm spacers is that due to the mrc struts?
Don't sit around and watch everyone else live YOUR dreams...DO SUMPT'N
When I see posts asking "whats the best intake, exhaust, etc" .... the answer to that is like a grandfather telling his grandkids "if you put salt on a birds tail, it'll let you catch it" #ThinkAboutIt
"Winning Tip: Don't take my (or anyone else's) word for it. GO TEST IT!" - Dennis Grant
PolynesianPowerhouse is offline   Reply With Quote
Old 05-21-2018, 09:38 AM   #7
Provoste
Provoste's Avatar
Thanks, yeah agreed. I'd be looking at 18x10/19x10 if I were in your boat too. The V6 1LE already punches above its weight in stock form, it would be a giant killer with 275/285 square!
All in, right at $3k with TPMS sensors. I purchased the orange TPMS reset tool off Amazaon for $18. Works great!
I haven't driven the new setup on track yet, but I have gone for a couple spirited drives on some empty country roads... I can tell you that the new setup definitly has more rear grip, you can get on the gas so early and so hard... It'll take a little re-calibration. The wider rear track definitly seems to help stablity as well.
I like the RS4's friction circle a little better than the RE71R, they communicate well, slide very progressively. Needless to say, I haven't run out of front end grip on the street, but he rear is very very planted. I'm very excited to see how the new setup performs on track. As for the sidewalls, I can't really tell much difference thus far. I will say the ride seems to be improved, this is in part due to the weight loss, but could also be a byproduct of a slightly softer sidewall.
BTW, I've been gathering wheel/tire weight data to share as well. Here is one tid bit:
The OE SS 1LE wheels w/ 295 RE71R weights are as follows:
Front: 58.0 lbs
Rear: 57.6 lbs
10.5 et 22 19" Apex EC7's with 305/30 RS4's: 55.6lbs
So 8.8lbs less unsprung weight with bigger tires. Not bad!
Originally Posted by mbar View Post
Looks great !
Yes, 5mm
Thanks, Yes indeed.
Old 05-21-2018, 10:29 AM   #8
Pollock
LT4 M6
Pollock's Avatar
Drives: 2018 ZL1 1LE
Looks Great!! Your car is so clean!!
Pollock is offline   Reply With Quote
Old 05-21-2018, 11:04 AM   #9
Provoste
Provoste's Avatar
Thanks... yeah, I detailed cars through high school and undergrad, that detailing bug never went away. I use my car really hard, but keep it very clean. Don't worry, there's plenty of road rash on the front and sides from track use.
Old 05-21-2018, 11:52 AM   #10
TrackClub
TrackClub's Avatar
Well checking the shoe prices up here...G3s are about $900US$ for a set while everything else is double that or more so i will be staying stock i am afraid...
Old 05-21-2018, 12:01 PM   #11
thescreensavers
thescreensavers's Avatar
Drives: SW 1SS 1LE / Jeep XJ
Where you finding G3 Supercars for 900?
thescreensavers is offline   Reply With Quote
Old 05-21-2018, 12:11 PM   #12
Provoste
Provoste's Avatar
Yeah, I'd stick with the G3's if they were that cheap too here!
Old 05-21-2018, 01:00 PM   #13
TrackClub
TrackClub's Avatar
Yep hard to resist at this price point!
Local online tire biz has them at this price, but unfortunately they dont ship to the US.
Old 05-21-2018, 01:51 PM   #14
GTSLOW
Daily Driven 1LE
GTSLOW's Avatar
Drives: 2018 1SS 1LE
Awesome! Thanks for sharing!
2018 1SS 1LE
GTSLOW is offline   Reply With Quote
