09-28-2020, 09:11 PM | #1 |
Drives: 2012 Camaro SS Convertible 6MT Join Date: Jun 2020
Kenwood deck or stock Boston Acoustic amp?
Hi all,
Ok I decided on some polks for my front stage. For the time being, should I run them in my kenwood dmx7706s or on the stock Boston acoustics amp. I’ll likely amplify next year but for now I just need to know what’s the best option of the two. Thanks your your advice. |
09-28-2020, 09:36 PM | #2 |
Drives: 2011 Camaro SS Join Date: Nov 2017
I went with a set of Rockford Fosgate R1675-S, which ran about $80. There’s a Punch series at $140 but the folks at Crutchfield said these would be fine since I’m running the stock BA amp through a Pioneer DMH-W4660NEX aftermarket radio. So far I’m satisfied with this set up, along with a powered sub.
My Little Mid-Life Crisis Cure!
First - 1997 Camaro 3800 Y87, M5, Green - Gone | Second - 1997 LT1 Z28, M6, Silver - Sold | Third - 1999 LS1 Z28, M6, Pewter, Almost Stock! - Sold Current - 2011 Camaro SS, M6, black, 1LE suspension parts - Current |
09-28-2020, 09:52 PM | #3 | |
I went Polk bc my intention is to upgrade the amp next spring. 100 watts rms so they can take a bit of power. |
09-28-2020, 10:23 PM | #4 |
They basically suggested just running everything through the aftermarket (PAC) harness through the BA amp, if that makes sense. I ran RCAs from the radio to the sub.
10-17-2020, 08:41 AM | #5 |
I run 2 catch cans...
The real question is how loud do you like your front stage? If you crank it up, and you power speakers off of the HU, you run the risk of either blowing the speakers due to HU clipping and/or burning the amp in the HU. The main problem with the OEM trunk amp is that the OEM speakers were 2-ohm, so 4-ohm aftermarket ones can only play half as loud. You might want to get a 100 watt amp for the front speakers NOW.
Overkill tuned • Air Scoop • CAI • VMAX PTB • JacFab Laminator FX + Extendolator • SOLO Hi-Flo Cats + Cat-Back Exhaust
View my top 3 LFX performance mods and more: . |
10-17-2020, 08:57 AM | #6 | |
Thanks! |
