03-07-2019, 02:03 PM | #1 |
Stock Goodyear Eagle F1 tires.
Hi everyone! As the snow is starting to finally part ways with us. I feel ready to take my Camaro out of storage. My only worry is that the stock Goodyear tires are going to crack. How cold does it have to be for the tires to crack? The weather calls for high 30’s-mid 40’s.
03-07-2019, 02:07 PM | #2 |
Drives: Too many to list Join Date: Dec 2011
This has been covered several times. The r-compound tires were prone to cracking in freezing weather. The Eagle F1 tires are not as susceptible to cracking the same temperatures. The warning for the Eagle F1’s are the same as any other summer tire, in that they require heat for traction and therefore a more optimal tire should be used in freezing/cold conditions.
I’d be more concerned with flat spotting, depending on how long the car has been sitting, than the F1s cracking. Sent from my iPhone using Tapatalk Pro |
03-07-2019, 02:11 PM | #3 | |
03-07-2019, 02:20 PM | #4 |
Drives: Camaro 50th anniversary edition Join Date: May 2017
Here is an extraction of the manual.
Soleil
_____________________________________________ A car is fast enough, if you fear to unlock it in the morning." (Walter Roehrl) |
03-07-2019, 02:26 PM | #5 | |
Drives: 6 on the Flo' Super Sport Join Date: Jan 2011
03-07-2019, 02:32 PM | #6 |
Drives: 22' Porsche PDK GT4 Join Date: Mar 2018
So why would you recommend a tire that you haven't put thru its paces yet???
Current:
22' Porsche PDK GT4 (MCS 2-way remote dampers) Previous: 18' NFG 2SS 1LE (ZL1 1LE solid rear cradle bushings & Corsa Exhaust) 16' F80 M3 (Ohlin R/T Coilovers) 13' Audi TTRS (APR Stage 1, MSS Springs) 09' C6 Z06 08' E90 M3 06' 335i (KW V2 Coilovers) 03' C5 Z06 |
03-07-2019, 02:47 PM | #7 | |
People are gonna people...gotta ignore them and stay out of their way. Anyone seriously driving around on summer tires in 25 - 30 degrees below 0 has a spot reserved on Darwin’s list. Wonder what part of MD he’s driving through in those temps. Sent from my iPhone using Tapatalk Pro |
03-07-2019, 06:02 PM | #8 |
Drives: 2018 2SS 1LE Black Join Date: Aug 2018
The least of your worries are cracking at those temps, anything under 40 and they have the traction of hockey pucks, toss in some rain and... His name was Azerlaser26
03-07-2019, 06:37 PM | #9 |
Drives: 2017 Camaro SS Join Date: Nov 2018
I remember the first time I drove on the summer tires under 40 degrees they felt as hard as bowling balls. It was weird. I ran out and got all seasons soon thereafter.
Kevin
Luceo Non Uro |
03-07-2019, 07:15 PM | #10 |
Drives: '18 Hotwheels 2SS Join Date: Jun 2018
Go easy on them until you are up into the 50's. I can spin them loose @1/2 throttle coming off or a roll say like a toll booth.
03-07-2019, 07:26 PM | #11 |
Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
Im in the same boat... Kinda. My winter vehicle needs a repair, so I have to take the Camaro out sooner than I wanted.
The Eagle F1 AS3 will be OK as long as you don’t drive in temps under 20F. On my SS, I drove those tires in the low 20s and the tires didn’t crack (but that is just my case). I think you’ll be fine as long as you aren’t driving around at night when the temps drop to about 20F. The temps in Michigan are supposed to be 30s to 40s, with some 50s, now... |
03-07-2019, 08:21 PM | #12 | |
Drives: 2SS Hyper Blue Join Date: Jun 2018
Will swap them out for the F1s in summer only.
2018 Hyper Blue 2SS - SOLD
03-08-2019, 01:01 AM | #13 |
Drives: 2017 2SS M6 Join Date: Jun 2013
under 40 get all seasons. dont take other peoples lives being cheap.
03-08-2019, 04:22 AM | #14 |
