01-24-2019, 07:45 PM | #1 |
2018 Camaro SS OEM side skirt part number?
Hi everyone! Does anybody have or know what the part number for the side skirts for the 2018 Camaro SS that are found on the ground fx package? If possible in mosaic black metallic?
01-25-2019, 09:00 AM | #2 |
Drives: 17 Z06/Z07, 17 2SS Fifty, Ram 2500 Join Date: Jan 2019
Good timing, I'm interested in the same thing!
01-25-2019, 09:03 AM | #3 |
Drives: 1994 z-28, 2017 2ss 6spd Join Date: Mar 2018
Body shops know the numbers.
I had some touch up paint work done in September and the part that you want was on backorder in Sept. 18. |
01-25-2019, 03:10 PM | #4 |
If they are the same as the ZL1, it's not "side skirts", it's the entire lower panel below the door, the side-skirts are part of them, not separate. Aftermarket side skirts are separate.
