10-13-2016, 03:14 PM | #1 |
Drives: 2010 Camaro RS/2SS Join Date: Sep 2015
*UPDATED 2010 2SS/RS 530HP For Sale $20K
I recently purchased a 2016 Dodge Charger RT as my family/daily driver and looking to move forward in life with my lady. With that being said, I have decided to list the SS for sale.
The car is in awesome condition. The interior is flawless other than a nick on passenger side leg jam from previous owner (not obvious). Non-smoker. Leather looks new. Garage kept. The motor is currently being freshened up at a performance shop, so the heart will be brand new when she's rolling again. I have several thousands of dollars in this car and only have the highest quality of parts and still selling less than any dealer asking price. I do not have any recent pictures of the car that shows the car lowered, but I'll post a couple of the car after I swapped to slotted/drilled rotors. FYI, the car paint stripes are graphite, not black. Side and rear windows are tinted. The car ran 12.08 in the 1/4 with exhaust only. Since then, it has been cammed/modded further. If someone wants to know the cammed/other mods time, I will be happy to video and provide slips once the motor is back in the car. I estimate an 11.5 on the 1/4- car is a M6. Car gets 24MPG at 72mph on highway. City varies from 16-18mpg depending on lights. Custom cam specs eliminated bucking/surge at lower RPMS- drives like stock. https://youtu.be/8ttYM4ZwPe8 2010 Camaro 2SS/RS LS3/Manual 6 speed 530hp/450rwhp $20,000 *Full leather interior (9.5/10 condition) *HID headlamps w/ halo projectors *Barton short throw shifter (46% reduction-have stock as well) *Brand new AC Delco maximum warranty battery *Brand new OEM AC compressor and lines *Bo White ported throttle body (he can also vouch for the car as I live close to him) *BTR Stage 4 Cam (231/248 .617/.598 120+5 LSA) *BTR .660 lift platinum dual springs *BTR hardened chromoly pushrods *BTR rocker arm trunnion upgrade *Revised timing chain guide *Hinson C7-R timing chain (Have stock) *New front case/water pump gaskets *Black Dog solid motor mounts (have stock) *BMR 1.5" lowering springs (have stock) *Kook's 1 & 7/8" Headers *Kook's 3" catback exhaust *Kook's mufflers *QTP low-profile 3" oval electric cutouts *New OEM slave cylinder *Tick Performance remote bleed line The car also has slotted/drilled rotors and a new set of rubber on the back. I am willing to travel a short distance for a sale. If you have any questions, cause I'm sure I may have left something out, PM me on here, email me at jakew1990@hotmail.com, or text/call 205-300-5085 (call after 5pm central time).
2010 Camaro 2SS/RS M6
12.08 @ 115 - 9/2015 (392hp/393tq) NA w/ Exhaust + Tune 11/2015 (464hp/439tq) ^ + BTR Stage 4 w/ Halltech CAI Engine: BTR Stage 4 Cam; BTR Dual Spring Kit; C7R Chain; LS2 Tensioner; High Volume Oil Pump Drivetrain: ACT T2S-G05 x2 Disc XT Street Kit Exhaust: Kook's 1 7/8" Headers w/ Off-road pipes;Kook's 3" cat-back; QTP 3" cut-outs Suspension: BMR 1.4" Front & 1.5" Rear Springs; Blackdog Solid Mounts w/ Poly Bushings Last edited by JakeW1990; 02-06-2017 at 08:12 AM. Reason: Trued up cost factors. |
10-17-2016, 08:10 AM | #2 |
bump
12.08 @ 115 - 9/2015 (392hp/393tq) NA w/ Exhaust + Tune 11/2015 (464hp/439tq) ^ + BTR Stage 4 w/ Halltech CAI Engine: BTR Stage 4 Cam; BTR Dual Spring Kit; C7R Chain; LS2 Tensioner; High Volume Oil Pump Drivetrain: ACT T2S-G05 x2 Disc XT Street Kit Exhaust: Kook's 1 7/8" Headers w/ Off-road pipes;Kook's 3" cat-back; QTP 3" cut-outs Suspension: BMR 1.4" Front & 1.5" Rear Springs; Blackdog Solid Mounts w/ Poly Bushings |
10-18-2016, 08:17 AM | #3 |
bump
10-18-2016, 08:17 PM | #4 |
GLWS, but curious as to how you like the ACT clutch? From a daily driver rating to a track rating? Can you slip it out of the hole still or is it too aggressive? What flywheel weight did you go with?
Been thinking about getting the ACT also
10-19-2016, 04:15 AM | #5 |
Drives: Savitar; The 500rwhp N/A Monster! Join Date: Aug 2016
Man, you got some serious money sunk in. Great price too. Good luck on selling it. New owner is gonna be a happy camper haha
*SOLD*504HP/433TQ | Night Fury cammed Cold Air Inductions intake Bo White ported TB Speed Engineering 1 7/8 longtubes NPP catback QTP low profile cutouts Powerbond 25% UDP 3.73 gears JRE scoop ZL1 grille R1 Concepts drilled/slotted rotors built/tuned by Weapon X Motorsports
10-19-2016, 07:25 AM | #6 | |
I posted it here: http://www.camaro5.com/forums/showthread.php?t=470212 I didn't get to drive it 1K miles, nor did I get to track it, but the break-in miles and extra 400 miles of DD with it, I LOVED it. So smooth. I went twin streets so there is a little forgiveness when slipping so it won't hang on you and stall. Once you break that window though it grabs and won't let loose until you press the clutch. I got the 1000ft lbs spec and the pedal feel is barely stiffer than stock. The initial push is a tad stiffer. I didn't think twin disc would help shift feel at all but I was wrong. Even with my 46% reduction shifter, it was smoother than ever. I had mine balanced and mated with ACT lightweight flywheel. Could definitely tell a differences when clutched/N and give it a rev- rpms climbed faster. My brother has triple disc Mantic and I get the ACT EVERY single time. Second to none.
10-19-2016, 07:37 AM | #7 | |
I have no doubt someone would be smiling ear to ear when they hear it or press the gas.
10-20-2016, 09:43 AM | #8 |
Price drop. I need this car sold as soon as engine shop is done freshening the motor up.
10-20-2016, 11:40 AM | #9 |
Drives: Camaro Join Date: Apr 2013
Did I miss the mileage on the car? What is all getting re-done in the motor?
10-20-2016, 12:00 PM | #10 | |
The motor will basically be brand new when I get it back. I had a bearing to start going out so it will be pressurized and hot boxed to be cleaned thoroughly. From there, the builder is replacing all bearings and bolts. All gaskets will be replaced. All moving parts, including cam/valvetrain, are being mic'd to make sure all tolerances are correct. The heads are being cleaned and inspected as well. I'm not saving a penny with this work. If my names on it, it's going to be done right. I label it as freshen up, but it's more of a rebuild. Stock compression ratio will be the end result UNLESS a serious inquirer puts money down on the car, and I will have them match whatever CR you want. The builder has an in-house dyno and it will be dynoed on the stand before it ever leaves the shop with all the paperwork with it. The car has absolutely no issues with any parts other than the motor- which is being corrected. I'm losing my a$$ off on this sale and I GUARANTEE whomever purchases this car will not stop smiling. I hate to see it go but I cant afford both payments and prepare for a family with the SS. Any other questions, feel free to ask. I will be straightforward about any of it.
10-20-2016, 12:18 PM | #11 |
The car has a brand new OEM AC Delco battery with the highest month warranty. 48 I think? I just replaced the entire AC system before the car went down for engine repairs as well. SUPER cold AC.
10-24-2016, 08:53 AM | #12 |
bump
11-09-2016, 04:19 PM | #13 |
Drives: 2013 ZL1 V3RT Join Date: Feb 2012
nice car... solid mods... Those cutouts hang pretty low huh? Any issues going over speed bumps? My headers would drag sometimes before I sold mine and that was with only a 1 inch drop
11-09-2016, 04:38 PM | #14 |
At first, I thought I was going to have clearance issues. I tested it in my driveway where there is an elevation change worse than a speed bump. I saw that it would scrape and went and made the solution: I put the stock tunnel brace back in with a little header wrap around that section of pipe that would be over it and added a few washer to clear better. I also undid the band clamps and rolled the cutouts up and out so they actually are tucked up under the car and the blow-downs redirect the exhaust. No scrapes thereafter. I'm sure if you have an extreme elevation change, it's a possibility.
I do currently have the stock springs if anyone wants them that purchases the car.
