Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Chevy Camaro vs...
Old 09-16-2023, 05:25 PM   #15
FasNuf
FasNuf's Avatar
Drives: 2014 Camaro ZL1
Originally Posted by ss camaro-monte View Post
11.7 at 122 with a 2.0 60ft. You got a lot more in it for sure. Low 11s capable just with better 60 and more tire. It is hard to run a stick good. My buddy runs about 490rwhp with a modded stick ss and he has a hard time getting into 11s. I ran an 12.3 on stock cam with just full bolt ons and stall with suspension and drag radials. I am hoping in the next few months to run my ss with 460rwhp auto. Think I will have close to your time but not that mph. You definitely got more in it. Good run.
Hey thanks, Appreciated.
I feel the run was terrible due to my noob skills and the power drop off was really noticeable because the heat pulling my timing. (10 degrees)
A month prior at the same track but unprepared, it ran a 12.5 at 127mph after spinning in 1st and 2nd gear so I know there's more speed to be had if conditions and my skills were spot on.
FasNuf is online now   Reply With Quote
Old 09-16-2023, 05:57 PM   #16
ss camaro-monte
Drives: 2015 camaro 2ss, 87 monte ss
127mph? Oh hell you got 10s in there if you can get it out of the hole. Cooler weather and tire and it's possible.There are guys with big cam ss in the low 11s high 10s with 124mph or around there, though most are autos but you certainly got the power for 10s. Makes me wish I threw down the coin for a zl1 to begin with. Everything about it is an ss on steriods. Easy to make big power and still run daily if you wanted to. You will get there!
ss camaro-monte is offline   Reply With Quote
Old 09-16-2023, 05:59 PM   #17
FasNuf
FasNuf's Avatar
LOl! Maybe next year but dang beadlocks and tires are $2K for a good set. Guy at work told me to get steelies and TEK screw them! LOL Nope.
Old 09-17-2023, 04:47 PM   #18
Modernmusclecar
Modernmusclecar's Avatar
Drives: 2011 Camaro SS
I ran an 11.7 @ 114 in 100 degree heat in July. You definitely are low 11s with that trap
EPS CUSTOM GRIND CAM....K@N CAI....VMAX PTB.....FRANKENSTEIN STAGE 2 HEADS ...1 7/8 STAINLESS POWER CATTED LONGTUBE HEADERS...CORSA XTREME 3 INCH CATBACK.....CIRCLE D 3800 Pro Series stall...391 gears.....Ported/modded GPI intake .Forgestar drag pack with Mickey Thompson ET street drag radials AGP PERFORMANCE DYNO TUNED. 463 WHP 428 FTLBS TORQUE.
Modernmusclecar is offline   Reply With Quote
Old 09-17-2023, 06:00 PM   #19
FasNuf
FasNuf's Avatar
Thanks for the info, Hope I can do this next year.
Old 09-17-2023, 06:47 PM   #20
Modernmusclecar
You will get there..your trap is key..the rest is seat time.
