AWE Tuning
Old 05-17-2020, 06:54 PM   #1
dzych
Drives: Camaro
Hurst shifter vs 1le shifter
Hi All, I’m tempted to pull the trigger on ordering myself the Hurst short throw that lets you use the oem knob. I love the white ball but not in the 1le interior. Many people do this mod and/or your opinions if worth the money over the stock 1le shifter? Any negative fb on this shifter? I had put a hurst in my ‘13 2SS and loved it. Darryl
dzych is offline   Reply With Quote
Old 05-18-2020, 08:38 AM   #2
Kmeleon
Drives: 2018 NFG 2SS 1LE!
From what I hear it's a serious PITA to swap? I heard it doesn't top load right through the cockpit?
Kmeleon is offline   Reply With Quote
Old 05-18-2020, 10:35 AM   #3
cmeJATT
cmeJATT's Avatar
Drives: SS-6-SPD
Hurst = really short
1LE = almost stock
PITA to install... if I had to choose go Hurst..
cmeJATT is offline   Reply With Quote
Old 05-18-2020, 02:24 PM   #4
Redlinez
Shifts under load
Redlinez's Avatar
Drives: 2020 Camaro 1SS 1LE rally green
I can barely tell any difference with my 2020 SS 1LE shifter VS the one in my 2017 Camaro SS
24 Audi S3 prem plus, sport package
HPDE - southeast - JTI- solo, PCA- blue.
22 Suzuki GSX-S 1000GT blue
Redlinez is offline   Reply With Quote
Old 05-19-2020, 08:29 AM   #5
Matos1LE
Drives: SS 1LE
I feel like you would have to drive both cars back to back for any difference to be noticed. Factory short shifters aren't normally as aggressive as aftermarket ones.
Matos1LE is offline   Reply With Quote
Old 05-20-2020, 07:47 PM   #6
Agent K
Agent K's Avatar
Drives: 2017 ZL1 6MT
Night and day. Very noticable after you first drive it. The precision is spot on. I kept my stock knob. BTW, the stock knob is nicely weighted. I've had the Hurst shifter for a while now and it's a solid engineered piece; no problems.
The bad: This is a tough install and requires (2) people at certain steps of the install and special tools. It requires dropping the exhaust, driveshaft, and transmission (slightly). On a scale of 1 to 10 for DIYers, this is a 10.
2017 ZL1 Arctic Blue Metallic / 6MT / sunroof / NAV / PDR / RotoFab CAI + dry filter / Tony Mamo TB V1 / Skip Shift Eliminator / Hurst Short Throw Shifter / ZL1 floor mats / Dead Pedal cover (to match other pedals) / ARH Catless 1-7/8" headers + ARH X-pipe + AWE Touring Axle-Back / Diode Dynamic smoked side markers / American Authority tow hook
Agent K is offline   Reply With Quote
Old 05-23-2020, 12:47 AM   #7
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
the 1LE shifter is only 6% shorter than stock the Hurst is 40% shorter. i recommend doing a softer reverse spring. https://www.ebay.com/itm/Soft-Revers...53.m2749.l2649 the reverse spring is easy to install if you have a pair of snap ring pliers. the shifter is time consuming but not hard. if you have a lift. i wouldn't do it on jack stands. id rather pay a gm performance shop to do it if i didnt have a lift. actually if you wanted we could do it on my lift. im 107miles from you.
Old 05-25-2020, 09:29 PM   #8
dzych
Drives: Camaro
Thanks all for the input I ordered it going to have a gm tech friend do the install for me cheers DZ
