05-04-2024, 11:17 AM | #1 |
Drives: 2010 Camaro SS Join Date: Jan 2023
LS3 engine swap
Anyone swap their L99 block for a LS3 block?
Looking at possibly doing a LS3 swap vs. a AFM/DOD delete and conversion with a stage 1 cam. Not really looking for crazy horsepower. Just thinking about using a new GM block, which go for about 6 grand and using my l99 intake and accessories. Would everything just bolt up to the block. Of course I know I need a new flex plate. Reason I am considering this, is doing a AFM/DOD delete would only be a few new parts, vs a complete new short block vs. my 50k miles on my L99. |
05-04-2024, 05:23 PM | #2 |
Drives: 2012 2SS/RS, 1968 SS Join Date: Feb 2012
Yep, had my L99 built and it blew up on the dyno.
Got a crate LS3, built that and had that installed instead of putting another L99 in there.
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS |
05-04-2024, 07:53 PM | #3 |
Want to remove those weak lifters. They are not natural, may be durable, maybe not. Mixed reviews. Trying to keep it as old school as possible.
05-05-2024, 07:26 AM | #4 |
I think your l99 is still like new at 50k not unless you've never changed your oil or something like that. I would be a hell of a lot cheaper to build the l99 than to buy a new ls3. For $6000 you could pay someone to do your dod delete for you tuning and all. And if you do I would keep your vvt.
05-05-2024, 09:55 PM | #5 | |
05-06-2024, 07:47 AM | #6 |
GPI Sales Consultant
OP - unless you're looking to go towards the max effort end of the spectrum (and your posts do not seem to indicate that) then deleting the AFM system and keeping the VVT system with a modest camshaft and quality lifters eliminates the weak point of the L99, while keeping it's stand-out feature. VVT is not failure prone, and provides a means to broaden the power curve and driveability that the LS3 does not offer. 50k miles is not high miles, and you're talking about a pretty major investment in an LS3 swap to "solve" a potential problem. You can spend less money and come away with a higher performing, more reliable result.
Got a question about a GPI product? Feel free to shoot me a message! |
05-06-2024, 08:11 AM | #7 |
If you are going to buy an LS3 bottom end, get it, preserve it, and keep it until (if) the lifters fail. You aren't saving much of anything doing it before the lifters fail.
05-07-2024, 04:51 PM | #8 |
Boosted Moderator
Guys,
Thanks for the reports, and please, in the future, just report any thread crapping and name calling. I appreciate it. I edited one post and removed any that included quotes. Carry on...
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. “If everything seems under control, you're just not going fast enough.” Mario Andretti If you can turn, you ain't going fast enough... |
05-07-2024, 09:16 PM | #9 |
Thank you SSE 4 2SS & Now back to the op. acammer nails these combos. I think the one thing to consider if you have the budget would be going a bit bigger with the cam & a higher stall tc especially with retaining the vvt. No matter what you do a great tune is a must no matter what you choose.
05-08-2024, 07:46 AM | #10 |
Appreciate your work helping keep the site cleaned up. It's a fairly thankless job, and super important. Seriously - thank you.
05-17-2024, 11:30 PM | #11 | |
Bought a used LS3 with 20k-ish miles, had it refreshed with a light cylinder hone, heads resurfaced, and of course all new gaskets/seals, etc...has been great since. L99 has been on an engine stand in house for 4 years now. Eventually going to have a machine shop inspect the block to see if it's still useable.
