06-18-2021, 08:10 AM | #1 |
Drives: 2020 Camaro ZL1 Join Date: Jun 2021
Any tracks that let convertibles on without rollbars - PA, NJ, NY, CT?
Hi All,
I have a 2020 Camaro ZL1 convertible. Was trying to book track days with it and the tracks I usually go to all require a roll bar. I will track it maybe 3 times a year and do not want to put in a roll bar. So I have two questions that I really need your help with 1. Are there any tracks in the PA and neighboring states that would let me do a track day without a roll bar? 2. Are there are easily removable roll bars for the 6th gen convertible camaro? I already check RPM and they are great but not at all something you can just put in and take out. Thanks alot!! |
06-18-2021, 08:46 AM | #2 |
Drives: 2019 ZL-1, Shadow Gray, Sold Join Date: Jan 2019
No tracks in the country will allow a convertible on without aftermarket or factory roll bars.
06-18-2021, 09:28 AM | #3 |
Drives: 997 GTS, ZL1 A10, ZLEM6, ZLEA10 Join Date: Dec 2017
i used to (about 6 years ago) track my 911 C2S convertible in Seattle. I believe the Porsche has pop out roll over protection - which qualified it without a fixed roll cage for track. Is this not the case anymore? or does the Gen6 not have pop up protection?
06-18-2021, 10:10 AM | #4 |
Drives: 2018 Camaro SS vert Join Date: Oct 2020
Yes, the pop up bar is what makes the car allowable on the tracks
No the Camaro does not have any such feature and also no there is no "temporary" bar you can fit in place then remove that I have ever seen
06-18-2021, 10:19 AM | #5 |
Absolutely, besides a temporary roll bar kinda defeats the purpose of a roll bar.
06-18-2021, 05:43 PM | #6 | |
Quite often it depends on the track and/or the type of event. I don't have a 6th gen, but I do have a 2013 ZL1 convertible that I have had on a few tracks here in Michigan. Milan drag strip allows convertibles during test/tune events (with no roll bar) as long as you run a 10.99 or slower. I've had it on Pontiac Mi's F1 track as well during a Haggerty fun day where cars are split into different classes based on experience. I ran in the novice group. I've had it on Michigan International Speedway several times during 'parade laps' with three passengers and the top down hitting 115+ on the back straight. I had in on Michigan's Gingerman's raceway as well with an instructor by my side in the novice group. None of these tracks/events required a roll bar in my stock convertible. However they may require that you have the top up. My point is, depending on your skill level and the track itself as well as the type of event, you may indeed have a chance to take it on the track to see what it can do. After that, if you decide to up your skill level or the particular track requires it, THEN you may have to install a roll bar that meets the tracks requirements for safety. |
06-18-2021, 05:58 PM | #7 |
Drives: Zl1 1le Join Date: Apr 2018
I wouldn't recommend that you do a track day without some type of roll-bar. As an instructor, I would never get in a convertible that doesn't have a roll-bar.
06-18-2021, 06:01 PM | #8 |
Drives: 2018 Hyper Blue ZL1 1LE Join Date: Dec 2018
The ZL1 convertible doesn’t have a rollover protection system that deploys when the car starts to go inverted? My 2002 M3 Cab had this, and MB had it on the SL in the early 90s. M3 roll bars deployed from rear headrests when I had a small front end collision that just lifted and tilted the car a little. That’s a big surprise and disappointment. How can Chevy sell a convertible without it, should be a law.
06-18-2021, 09:12 PM | #9 | |
Drives: Wild Cherry LT1 Join Date: Dec 2016
06-18-2021, 09:39 PM | #10 | |
I went to a track rental a few weeks back and they were a lot more lenient which was good because every single one of my runs was faster then 13.49
06-18-2021, 09:59 PM | #11 | |
Drives: 18 ZL1 Convertible Join Date: Jun 2019
06-18-2021, 10:06 PM | #12 | |
Retired from GM
Drives: 2017 Camaro Fifty SS Convertible Join Date: Mar 2017
I’ve also done a number of “controlled events” at M1 Concours, as HDRDTD mentioned he has done. Still remember my first time out at M1. Hitting 130 on the long straight then having an underwear check when I went into the following corner just a leetle too hot. The one pic is me holding off a late charge from a friend’s SS Coupe at Lapeer, the other is our post event photo of the Small Block Mafia my 1st time out at M1 Concourse. I was the slowest of the group. By a lot.
A8 | MRC | NPP | Nav | HUD | GM Performance CAI | Tony Mamo LT1 V2 Ported TB | Kooks 1-7/8” LT Headers | FlexFuel Tune | Thinkware Q800 Pro front and rear dash cam | Charcoal Tint for Taillights and 3rd Brakelight | Orange and Carbon Fiber Bowties | 1LE Wheels in Gunmetal Gray | Carbon Fiber Interior Overlays | Novistretch bra and mirror covers | Tow hitch for bicycle rack | |
06-18-2021, 10:13 PM | #13 | |
Perhaps the new owner44s will have new rules. It's also possible that the rules differ if it's an official NHRA race day, or a more casual test/tune day. Always check the current rules/regulations of any track or event you plan on attending just to be sure and safe. |
06-21-2021, 09:03 PM | #14 |
Drives: 2018 ZLE, 2023 C8, IMSA MX-5 Join Date: Jul 2019
Last two track events (road course) 2 rollovers, Miata at Roebling and S2000 at Road Atlanta, Miata was caged with hardtop, not sure about S2k protection, both walked away. Miata cage and passenger seat were displaced but intact. This year, 4 red flags year to date. Not good.
convertible, rollbar, track days |
