05-21-2016, 11:02 PM | #1 |
Drives: 2016 Mosaic Black Camaro 2SS Join Date: Nov 2015
Bug goo removal
Anyone know how to safely remove bug splats from front fascia?
2016 Camaro 2SS
05-21-2016, 11:34 PM | #2 |
The Dogfather
Drives: #1 off the line for a customer. '16 Join Date: Oct 2015
Turtle bug and tar remover spray and wipe off with a MF towel or even a blue shop paper towel.
05-22-2016, 01:25 AM | #3 |
Drippin' Wet Auto Detail
This sponge and remover works great. Check it out
http://www.autogeek.net/diamondite-bug-eraser.html |
05-22-2016, 01:59 AM | #4 |
Drives: '16 2SS Join Date: Nov 2009
Someone mentioned on here to use a spent dryer sheet moistened. I think it was Modshack. It's supposed to me a real hack...
My Intro Post | My Order | My Ordering Guide
TJCR2Q | 2SS Red Hot|Adrenaline Red|MX0 A8|56R Wheels|5ZU Blade Spoiler|NPP Exhaust|F55 MRC|IO6 Nav 4/06/16 1100 Ordered (waiting for 5ZU acceptance) 4/19/16 2000 Accepted with 5ZU 4/23/16 3000 TPW:5/16/16 5/06/16 3100 5/13/16 3400 Broadcast Sheet 5/24/16 3800 Vehicle Produced 5/25/16 4B00 Bayed 5/27/16 4300 Intermediate Delivery 7/9/16 Delivered! |
05-22-2016, 06:53 AM | #5 |
Retired from Car mfrs....
Drives: 2LT RS/HR-V Join Date: May 2013
Soak it with a hot wet towel for a few minutes, use the dryer sheet, works well. If you want a product to help, get some poorboys "bug squash". Dont scrub, wipe. Rewax or seal.
05-23-2016, 11:06 AM | #6 |
Drives: 2013 ZL1 M6 Join Date: Oct 2013
I presoak with a waterless wash to soften them up. Then use a bug sponge lightly to remove. Anything that might be left after that gets clayed using a clay bar. I don't use the clay towel for that process. What ever you do don't scrub them off.
Sealants , or coatings make the removal even easier, and they can be sprayed off it the bugs have not had time to bake onto the surface for days. You can also use waterless wash to remove them while they are still fresh on the surface. I do this often when on road trips. |
05-23-2016, 12:05 PM | #7 |
Drives: 2SS, Hyper Blue Join Date: Feb 2016
Yeah...Try it. Easiest bug removal method I've ever used and I've been doing this for awhile..
Steve
Hyper Blue 2SS, 6M, NPP, Sunroof, Nav |
05-23-2016, 12:27 PM | #8 |
Drives: 2016 Camaro Join Date: Mar 2016
squirt them with windex and let it soak for a minute or two and wipe them off. Not sure if windex will remove any wax underneath though. I always do a quick re-wax on the front facia afterwards. Ive never tried the dryer sheet method. I'll give that a try next time.
2016 Garnet Red 2SS M6 MRC NPP and Sunroof
100% Stock - 12.10 @ 115.6mph - 3620 lbs lookin' at it |
05-23-2016, 02:57 PM | #9 |
Drives: 2016 Camaro 2SS Bright Yellow Join Date: Apr 2016
Best product I have found is SeaFoam Bugs-be-gone. It doesn't seem to strip the wax and works better than any other products I have tried. The only place I have been able to find it, in my area, is Rural King.
2016 2SS, M6, NPP, MRC, Magnuson 2300,
JRE Rough Idle Cam, 95mm TB, Dynatech headers, Cat delete, Borla ATAK |
05-23-2016, 05:02 PM | #10 |
Drives: The shiny ones. Join Date: Mar 2010
After spraying your car off and before doing your two bucket wash spray down the bugs with Waterless Wash and let them soak while you are washing the rest of the car.
The WW will loosen the bug guts and they will come off easier. Tip, the sooner you can get them off the better. If you find old bug guts you will have to clay to get them off. http://adamspolishes.com/shop/exteri...-car-wash.html |
