11-24-2017, 11:00 PM | #1 |
Drives: New : 2017 SS 1LE Old: 2012 TTRS M6 Join Date: Oct 2015
295/30R19 tire too wide for 19 x 10" wheel ...?
I am looking to fit Michelin Pilot Sport 4S tires for Spring 2018... they don't make a 285/30R19 and I don't really want to go down to 275/30R19 and lose some of the front end bite.
I worried about possible handling issues since 285 is considered the upper range for a 10" wide wheel... I might consider getting an all new setup with adjustments stable camber plates from Morena, and Z06 front spats and trimming down the MRC shock to go whole hog with : 305/30r19 front on a 19x11 ( or 10.5) and a 325/30r19 rears with a 19x12 wheel Thoughts ? Suggestions? EDIT: realized the title had the original size... tital now says 295, not 285
. https://www.wheelwell.com/profile/56...ed9c3a/garage/ . . Project 1LE Wraith: http://www.camaro6.com/forums/showthread.php?t=474068 Last edited by aa406079; 11-25-2017 at 05:38 PM. |
11-25-2017, 12:17 AM | #2 |
Drives: MB 1SS Join Date: May 2017
285 is a perfect for for 10 inch width. 9.5 is minimum and 10.5 is max per manufacturer. I dont know why you think its narrow.
9.5 = 275 10 = 285 10.5 = 295 11 = 305 |
11-25-2017, 05:39 PM | #3 |
sorry, my subject title should have said 295/30r19 , not 285/30R19 on a 10" wide wheel
. https://www.wheelwell.com/profile/56...ed9c3a/garage/ . . Project 1LE Wraith: http://www.camaro6.com/forums/showthread.php?t=474068 Last edited by aa406079; 12-02-2017 at 10:58 PM. |
11-25-2017, 05:45 PM | #4 |
Drives: 2017 1SS 1LE Join Date: Aug 2017
It fits fine. I’m running 295/30/20 on the OEM 1LE wheels. No clearance issues at all.
11-25-2017, 05:52 PM | #5 |
Also different manufacturers measure their tires differently. Dont chase a size. Look at the actual dimensions. For instance, a Michelin Super Sport runs very wide while Nitto tires are more narrow. It also has to do with the shoulder blocks. Some are more squared while others rounded.
11-26-2017, 12:38 AM | #6 |
Drives: '19 RivrsdBlu 1LE ('17 1LE HB sold) Join Date: Nov 2016
It should be just fine
By the way, I was using 305/30/19 and 325/30/19 on 10.5" and 11" wheels with no ill effects
11-27-2017, 08:39 PM | #7 |
ITCRNRS
Drives: 2018 ZL1 1LE Join Date: Jun 2012
I run a 305/30R19 on the front of my 19x10 autocross wheels, as does every other FS 1LE 5th gen Camaro with no issue.
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV, https://www.youtube.com/c/tylerpotter
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Brembo swap |
11-28-2017, 11:24 AM | #8 |
i wanted 285 in front on my car on 20x10 wheel but ordered 275 and they fit wide and they run wide btw lol good luck
