03-23-2019, 11:00 AM | #1 |
Drives: 2018 Camaro 2SS Redline Convertible Join Date: May 2016
Fastech Color Matched Cover Install
I just installed the Fastech aluminum cover kit in white on my Redline SS Vert. The match to the car's Olympic White by the powder coated covers was good enough that any color difference was not apparent. I deviated from the Fastech instructions by using adhesive Velcro rather than the supplied double stick so I could remove the covers without any problems. I did use the adhesive foam supplied by Fastech to eliminate rattles. I've attached photos illustrating the installed covers and Velcro placement. Also, you might notice the Chevy performance emblem on the center cover. I used a heat gun and a plastic tool to remove the emblem from the original sheet metal and then attached it with double stick tape. My SS is a daily driver that I also show, so the white panels not only look good, but are much easier to clean than the original sheet metal that often held water spots.
2019 Buick TourX
2017 Colorado Redline 1966 Ford Mustang Pro Touring Last edited by ac-427; 03-23-2019 at 11:23 AM. |
03-23-2019, 11:10 AM | #2 | |
BL1ZZRD
Drives: '16 Camaro 2SS, '20 Equinox Redline Join Date: Jul 2009
03-23-2019, 05:34 PM | #3 |
2019 Buick TourX
2017 Colorado Redline 1966 Ford Mustang Pro Touring |
03-23-2019, 08:29 PM | #4 |
Drives: 2019 ZL1 A10 Join Date: Jan 2019
Good looking unit
03-24-2019, 12:01 PM | #5 |
Drives: 2018 2ss 1le Join Date: Jan 2018
how much
2018 2ss 1le roto fab dry, Stainless works 1 7/8 lt to 3'" x pipe with highflow cats to stock npp, soler 95mm t/b, edelbrock 2300, LT4 fueling , jms bap and dsx flex fuel, 618/620 on e45 rwhp
Jannetty Motorsports tuned |
03-25-2019, 04:59 AM | #6 |
I got them for $99 plus $20 for white powder coat with free shipping.
2019 Buick TourX
03-25-2019, 06:28 AM | #7 |
Drives: 2016 Camaro 2SS Join Date: Apr 2017
Can you please post the link to where you purchased these?
2016 2SS, MRC, NPP, A8. Procharger P-1X,Stage II,std bypass, 3.9, Alky Meth - 10.84 @129 - DA+2000
New Mods - GPI drop ins, Kooks 2", LT4 fueling, Cam, Circle D Converter, 3.5 pulley & dual nozzle meth. |
03-25-2019, 11:43 AM | #8 |
2019 Buick TourX
Thread Tools | |
