11-08-2016, 10:43 AM | #1 |
4Harambe
Drives: 2016 Camaro 2SS 6Speed Join Date: Sep 2014
Stabilitrak and Power Steering "Issues" After Installing the Headers
Recently, I had a pair of Kooks long-tube headers installed. It sounded amazing, and I loved it. I've run into a slight issue though. I'm receiving an error on my display saying that Stabilitrak and power servicing needs servicing. We did disconnect the steering column prior to installing the headers, because there was practically no clearance, and we did it in a garage (not a shop), so we had no hydraulic lift to do it (just a jack and some stands).
I'm not having any issues turning, however I have noticed the following:
Before I continue, I ask that rude comments be put to a minimum; I'm not incredibly experienced with vehicle maintenance (honestly, I figured installing the headers would be easy, since we did it on my 2013 1SS a while ago). Thank you. From what I've been told, my steering wheel was most likely, accidentally rotated 360 degrees to the left, which is why my backup camera guides are pointed far left, instead of straight. Before I do anything stupid, or cause any more possible damage, would I just have disconnect the steering column from the steering wheel and rotate the wheel 360 degrees to the right, then reconnect the steering column?
11-08-2016, 11:05 AM | #2 |
Drives: 08 Accord V6/M6 / 04 Canyon Z71 Join Date: Aug 2008
By steering column, did you remove only the shaft under the hood, or also the interior column and steering wheel?
Could be something wrong with the steering angle sensor and also potentially the airbag coil causing the weird feel. When disconnecting the steering you have to be careful to keep the wheels aligned. The column to wheel connection also affects the airbag coil. If something is off, the steering angle sensor has to be reprogrammed. I would recommend taking it to a shop or dealer to be checked out. |
11-08-2016, 11:17 AM | #3 |
4Harambe
It was disconnected at the shaft near the rubber boot.
11-08-2016, 12:37 PM | #4 |
Drives: 2019 Shock ZL1 Join Date: Jan 2007
Sounds like the steering wheel was turned one way or another and threw the steering angle sensor out of whack perhaps.
From Super Chevy mag, April 2002: "Most of the weekend Settlemeire was meeting and greeting and quickly became known as simply "The Camaro Dude" (note, even his initials are SS)."
11-08-2016, 12:46 PM | #5 |
4Harambe
Yeah, we never disconnected the actual steering wheel from the steering column, just unscrewed from the rubber boot to move the column out of the way to fit the driver-side header. I think from what my friends were saying, the steering wheel may have turned, and when they reconnected it, basically was 360 degrees left.
So essentially, we just have to turn it right... Right? lol
11-08-2016, 01:30 PM | #6 | |
11-08-2016, 02:30 PM | #7 |
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova Join Date: Oct 2008
I think you rotated the steering wheel and not the clock spring in the column is off, i know in the 5th gen cars if you changed stirring wheels this can happen with the same problems.
03-17-2018, 12:18 AM | #8 |
Drives: SRT4, 2ss Join Date: Nov 2016
What ended up fixing your issue?
09-04-2018, 07:17 PM | #9 |
Drives: 2020 Chevy Camaro ZL1 1LE Join Date: Nov 2017
any update? I am having the same scenario.
09-04-2018, 10:01 PM | #10 |
Drives: 2018 Camaro ZL1 Join Date: Feb 2018
Either disconnect the shaft again rotate your wheel back, or reset the steering angle sensor with a scanner.
09-05-2018, 10:24 AM | #11 |
Also make sure you have allowed ample clearance between the header and engine harness that runs down the passenger side fender well. Many folks have burned the wiring there after a header install.
2016 NFG 1SS A8
Thread Tools | |
