Roto-Fab
Old 03-05-2017, 09:21 AM   #1
sbubbaklein
sbubbaklein's Avatar
G8 differential in a v/6 auto
Will a G8 diff fit in a V/6. I was looking at a V/8 model and it appears to be a diff that the G8 owners are using.
I am looking for an economical LSD rear end for my 2011 vert currently with an open diff.
What axles and drive shaft would I need?
Old 03-06-2017, 10:18 AM   #2
sbubbaklein
any body tried install of G8 diff?
Old 04-08-2018, 11:42 AM   #3
veperformance
Drives: camaro2000 / 2010 gtatransam1989
Send a message via ICQ to veperformance
Smile direct fit
It is a direct fit , i just installed one.The only difference is the breather tube witch you have to relocate.As a bonus it is 7.8lbs lighter.No need to disconnect the cv from the wheel bearing.
veperformance is offline   Reply With Quote
