Roto-Fab
Old 04-08-2014, 04:40 PM   #1
jonathanmoguel
MM.CC
jonathanmoguel's Avatar
Drives: 2010 Camaro 2SS LS3
nitrous results..
hello C5,
well i posted this on another thread but i thought i would post it here as well,
i was able to get my nitrous running last week while struggling to get the software from the progressive controller to work.
i have installed, the nitrous outlet kit 90mm plate system, with bottle heater and purge kit.
it is controlled by the NX maximizer 4 controller..
i have it jetted to 100 shot, .52 for nitrous and .31 for fuel,
today i went to Izzy Performance in Gardena CA which BTW are Awesome there great guys.. and
i ended gaining 61 hp and 105 tq!
the stock pull was 431hp and 416tq.
Izzy, the shop owner said it seemed good, regarding my tune is based on a email tune..
it was tuned my monte06ss from ls1tech.. and from the diablosport fourms..
my question to you guys is why i gain more tq than horsepower? can it be from the tune or from my bolt on setup?
i do have shorty headers paired with catless midpipes. the shop who performed the dyno suggested swapping them to longtubes..
2010 camaro ss: Volant cold air intake, BBK Shorty Headers, JBA offroad midpipes, Diablosport tuned (custom tune), SLP II loudmouth axleback, ZL1 Short shifter, nitrous outlet wet "100 shot"
jonathanmoguel is offline   Reply With Quote
Old 04-09-2014, 02:08 AM   #2
shiznight
Drives: 2010 camaro ss l99
long tubes didnt bring down my tq on a 100 shot, but my spike was from the rail leaning a tad and the pump playing catch up. i'll link my video for ya. i'm also running a zex kit.
first vid is a 125 shot
second video is after long tubes and vvt-1 cam
in both instances i had a huge torque spike but it does platue off a bit after the fuel catches up. our cars being a pushrod motor will always pump out more tq than hp until you go with a massive cam. just how we overhead valve cars work. hope this helps, and if you have any questions, let me know.
TSP vvt-1 cam, Headers-catless xpipe, Knn intake 417/422
Nitrous 100 wet shot 520/585
Racestar super 94 17x4.5/17x9.5
highest trap to date 120.6mph
12.0@spinfest. rage
shiznight is offline   Reply With Quote
Old 04-09-2014, 02:27 PM   #3
jonathanmoguel
MM.CC
your car pulls really strong with that cam! awesome..
so you think I should contact my tuner and revise my tune..? right now the nitrous tune pulls 4 degrees of timing at 3600 rpm..
or should I install a wideband and tune with that?
Old 04-09-2014, 03:51 PM   #4
MudderFinger
MudderFinger's Avatar
Drives: 2011 IOM SS/RS
your results with torqe will vary depending at where in the rpm range you decide to activate the Nitrous, the lower the rpm the higher the torqe, because Nitrous flows the same rate regardless of engine speed, and because at lower speed there is more time between engine cycles the amount of Nitrous is higher per cylinder at lower speeds. Great results, you can't go wrong with Nitrous Express they make some of the best kits out there. NX normally recommends pulling 1 degree for each 50HP increase. So you should pull at least 2 degrees.
MudderFinger is offline   Reply With Quote
Old 04-09-2014, 04:57 PM   #5
jonathanmoguel
MM.CC
so I spoke with Brandon at nitrous outlet and he told me it was kind of low on the horsepower side. he recommended me to go to a .28 fuel jet and play with the timing to see where it would make the most power..
he said the target a/f ratio should be around 11.8-12.0
so it seems that the tune might be the issue there.
Old 04-09-2014, 05:45 PM   #6
Bubble85
Drives: 2012 SS
I had basically the same mods as you and I gained a lot more hp with a 100 shot. I can't remember the exact numbers but it was 80-90 I believe
Bubble85 is offline   Reply With Quote
Old 04-09-2014, 08:11 PM   #7
Badbubba
GrINned & JUICEd
Badbubba's Avatar
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1
Yes generally. But OP stated he has a progressive system. All depends on what starting percentage, ramp rate and reset is programmed.
Badbubba is offline   Reply With Quote
Old 04-09-2014, 08:16 PM   #8
Badbubba
GrINned & JUICEd
Badbubba's Avatar
Some N2O systems are not rated as rwhp, but as flywheel. But regardless, the hp number seems somewhat low. If you can, do a wot pass and read the plugs. A wideband can help, to see how much of a lean spike you get on activation and afr, but ultimately read the plugs.
Old 04-10-2014, 02:22 AM   #9
shiznight
zex rates at the flywheel, and you having shorties is also hurting you. toss on some longtubes man. they are well worth the 360 for some pacesetters. or obx's. also i spray at 3200 rpms until 6300rpms (auto). your power seems legit considering the jetting chart zex puts up isnt true whp
edit. what you typed vs what i see on the dyno are different. is it a typo?
12.0@spinfest. rage
Old 04-10-2014, 11:49 AM   #10
jonathanmoguel
MM.CC
yeah i will probably check out the plugs when i get a chance.
i went with 1 step colder NGK BR6EF plugs.
i have the progressive controller setup to receive a wideband connection but i haven't gotten around to install that either.
Old 04-10-2014, 11:51 AM   #11
jonathanmoguel
MM.CC
yah i am starting to think i should look around for a good set of longtubes
at the time i thought well making 431hp and 416tq N/A, on shorties is good but it seems that cars with longtubes carry the power more throughout the rpm range. i bet i'll see more power when the n2o is used.
