12-14-2012, 08:04 PM | #1 |
MM.CC
Drives: 2010 Camaro 2SS LS3 Join Date: Jan 2011
Cat deletes and BBK shortys
i recently installed the 1 3/4 BBK shorty headers with the JBA Offroad midpipes(catless)and sounds beastly and goes really well with the SLP Loudmouth 2 axlebacks!
just some questions that i would like to get answered. is the TQ moved up higher in the powerband? it seems like its smoother, or slower at low rpms, but i look at the speedo and it picks up mph at a faster rate.. and do i need a tune to get the best out of this setup? i went with shortys because i live in cali so i can just swap the offroad pipes and but the stock cats back on. i got a friend that can pass me on the smog and the shortys were bought at a low!! low! price. so i couldnt pass them up.. thanks for the replies |
12-16-2012, 10:03 AM | #2 |
MM.CC
So im guessing no one has ant comments thoughts? :(
12-16-2012, 04:01 PM | #3 |
Drives: 2010 SS/RS Rally yellow Join Date: Jul 2012
I would tune, Optomize those mods you have. Im curious to see what you get, I just did cat deletes and my dyno came close to people with long tubes. Wonder if shortys provide anything. I was hesitant on the purchase. Planning to use the money towards a vvt cam.
12-16-2012, 05:13 PM | #4 |
Yes, decreasing back pressure with larger pipes or removal of cats will cause your torque curve to move up in RPMS.
Yes, a tune with any modification will help to get the most out of the mod. Now get you a CAI, tune, and move out of California and you will be on the right track to make some good power numbers.
2014 1SS 1LE, bone stock for now.
12-16-2012, 05:46 PM | #5 |
Yea. You're gonna move the torque higher in the range. And yea, tune that sucker!
12-16-2012, 06:25 PM | #6 |
V8 Lounge member #2
Drives: 2001 Ws6 Join Date: Sep 2009
I don't think your gaining that much with your mods to be honest with you. A tune will help a Lil bit. But if you are willing to tune why didn't you get the Lt's for some real gains!
2001 ws6, 40k miles, Ls3 416 stroker, short block built by PER the rest by me. LPE Ls3 heads milled to 12-1 comp, FAST 102, NW 102, kooks 2", dual DMH cutouts, Magnaflow C/B, BTR cam + springs. Full UMI suspension.
12-17-2012, 11:49 PM | #7 | |
MM.CC
Thnx for the input Last edited by jonathanmoguel; 12-18-2012 at 12:12 AM. |
12-17-2012, 11:59 PM | #8 |
MM.CC
I guess i"ll tune the sucker.. It certainly feels alot faster in terms of how the mph climbs lol.when i go WOT in second going into third, its alot faster too ..
Im going to Irwindale Speedway this thursday. Hopefully my time goes lower.. Ill keep yall posted! Last edited by jonathanmoguel; 12-18-2012 at 12:10 AM. Reason: Spelling |
12-18-2012, 12:08 AM | #9 | |
MM.CC
(i kinda tripped out with those numbers! ) I know it has a stock tune because the governor kicked in and my cel light is on with the cat deletes I wonder how much more hp it will be with shorties and cat deletes! |
12-18-2012, 05:38 AM | #10 | |
V8 Lounge member #2
12-18-2012, 08:19 AM | #11 |
MM.CC
Yah i am surprised myself! I think maybe not sure tho, it was because i had all the fluid changes before the dyno run ..diff oil change, trans change ,and oil change. The dyno run was done on a dyno day so a bunch of other cars went before me.. I was on right after a mustang it put out 260 whp so i dont know if all those cars that got on before me messed up the calibration or something.. There was a 11 camaro with a similar setup. muffler deletes, a cold air induction intake, and was a manual trans like mine. He put out 388whp so a 10 hp diffrence !? You think its too far off to be a miscalculation or the car is a factory freak? Ill tell u this though on the street i beat 13 mustangs by a car and a half, (friend of mine) with intake and a tune!
So idk about my car! |
12-18-2012, 09:31 AM | #12 | |
I have an l99 and came out with 354/376. I was comparing on the l99 dyno thread and I was withing 5-10 hp/tq. |
12-18-2012, 03:06 PM | #13 |
MM.CC
