09-20-2021, 06:32 PM | #99 | |
Drives: 2018 Camaro ZL1 Join Date: Aug 2018
Plus, if they were to brake them out would be very expensive to fix just 1. I'm not even sure how maintenance is and I'm not sure if you have to get certain pads. It's up to you. If you want them then go ahead but I would listen to others on here and also search the internet for other opinions. Edit: Here's a decent read about a ZR1 owner, who tracks his car, debating to get rid of his CCB for iron. https://www.corvetteforum.com/forums...go-w-iron.html Last edited by Vigilante375; 09-20-2021 at 06:42 PM. |
09-21-2021, 09:56 AM | #100 |
Drives: 2019 ZL1 Riverside Join Date: Apr 2020
$120k heavy luxury track car - kind of strange. Tracking any car kills the value.
Why not buy a 2017 ZL1 for $50k and make a track beast out of it |
09-21-2021, 10:07 AM | #101 | |
Drives: 2019 ZL-1 Join Date: Feb 2009
4400 lb car..... I will keep my ZL1
2019 ZL-1 Acquired 4/23/21 at 6300 miles. Riverside Blue, A10, PDR. Traded in 2017 2SS with 6M and 32k miles. Continental Extreme Contact Sports. Now has 10,000 miles...
2012 Yukon XL Denali w/ 6.2 AWD |
09-21-2021, 10:35 AM | #102 |
Drives: 2021 Camaro ZL1 A10 Join Date: Nov 2018
Are you just making up that weight? C&D tested the M6 CT5 Blackwing and it was 4,092 lbs with the carbon ceramic brakes (which obviously reduce weight). The auto will be slightly heavier but not much. While it's not lightweight, it still undercuts the BMW M5 by ~200 lbs and its 400 lbs lighter than an AMG E 63 S.
2021 Camaro ZL1 A10
2022 GR Supra 3.0 Past: 2018 Mustang GT Premium w/ PP1, MR, and A10 2007 MazdaSpeed3 1995 Pontiac Trans Am 1987 Camaro Z28 |
09-21-2021, 10:51 AM | #103 |
I was thinking the CT6.... but still not a light. a
The REAL point is why are we talking about a heavy sedan.... I will keep my ZL1....
09-21-2021, 10:52 AM | #104 |
Drives: '16 Camaro SS 6 spd manual transm. Join Date: Aug 2012
'16 Camaro SS
Prior cars: '14 Corvette C7 Stingray Z51 '14 Camaro ZL1 w/. Recaro seats '11 Mustang GT 5.0 w. track package '02 Porsche 911 Carrera '05 Infiniti G35 coupe sport Last edited by Bosse'sBoss; 09-21-2021 at 04:43 PM. |
09-21-2021, 12:09 PM | #105 | |
Drives: 23 LT1/22 Colorado TB/69 Chevelle Join Date: Jun 2006
09-21-2021, 12:20 PM | #106 |
Drives: Garnet Red / ZL1 1LE Join Date: Apr 2016
The only reason I lurk in this thread is to figure out if there is an easy swap of parts from the BW to our ZL1 that can get us the net +18hp.
If it requires a tune (then forget it).
#SAVETHEMANUALS
09-21-2021, 02:11 PM | #107 | |
But you would still void your warranty (if you're concerned about that) because its not OEM to the ZL1 and I'm certain you would need a tune. I bet even if someone were to go through with it, it would be more beneficial to spend the same amount of money for a pulley swap and tune because you'd get more performance out of that. |
09-21-2021, 02:15 PM | #108 | ||
Drives: Fast Join Date: Mar 2015
The differences between the 668 HP LT4 and the 650 HP LT4 are due to the supercharger lid and exhaust (mainly at least). The lid may be swappable but tuning requirements are undetermined still.
Now if you don't want the Blackwing because it's a sedan or $100,000+ or some other reason, that's fine. Also, you do not have to read the thread. |
