08-21-2016, 08:59 PM | #1 |
Use the Force
ZL1 LT4 vs Corvette LT4
Here are some pictures I took of the new LT4 S/C cover on the ZL1 and how it compares to the original LT4 Cover used on the ZO6 Corvettes. You can see that it is about an inch taller than the first design. Engineers at the Camaro Rally said that it helps to cool the rear cylinders which was one of the overheating problems on the ZO6 Corvettes. They seemed pretty confident that the ZL1's will not overheat or pull timing because of heat.
Walk softly, carry a light saber and drive a ZL1!
08-21-2016, 09:04 PM | #2 |
Drives: 2017 SS 1LE, 2017 Volt, 2013 Pilot Join Date: May 2014
we will find out soon enough. with the issues in Z06, this will be top on list for the professional tests and reviews.
2017 SS 1LE | HBM | Vortech V3-Si supercharger (620RWHP and 575ft lbs) | PDR | Black Bowties | Illuminated Front Black Bowtie | Illuminated Door Sills | Smoked Tails | vented seats mod
08-22-2016, 12:00 AM | #3 |
Drives: 66 Chevelle SS Join Date: Mar 2013
I'm sorry guys but these new generation engines remind me of some kind of carrying case. They are so unattractive they have to hide them with covers.
08-22-2016, 01:46 AM | #4 | |
Drives: C4,C6 Z06,Silverado,'17 Red Hot ZL1 Join Date: Aug 2016
Most of today's engine bays are just plastic covers anyways |
08-22-2016, 02:00 AM | #5 | |
Drives: Nothing Fast (Yet) Join Date: Oct 2015
08-22-2016, 06:38 AM | #6 | |
Drives: 2015 Blue Velvet Metallic ZL1 Join Date: Nov 2013
08-22-2016, 06:58 AM | #7 |
I am pretty sure there needs to be a certain amount of space beyond what would work functionally between the hood and the top of the engine. This is something i would def swap to if i own a Z06
08-22-2016, 12:37 PM | #8 |
The Dogfather
Drives: #1 off the line for a customer. '16 Join Date: Oct 2015
ZL1 LT4 has a larger SC cover for more cooling also, ZL1 LT4 has TRI-Y headers where as the Zo6 LT4 does NOT.
08-22-2016, 09:17 PM | #9 |
Use the Force
I'm pretty sure that there are some internal changes to the heat exchanger to aid cooling as well.
