05-13-2016, 02:34 PM | #1 |
Use the Force
Slotted vs Non-Slotted Rotors
So I have noticed that the stock SS, 1LE and ZL1 rotors are solid and not slotted/grooved in any way. However the Chevy upgrade 6 piston brake package and the Corvette Z51, Grand Sport and Z06 all come with grooved/slotted rotors. Any idea why the stock HiPo Camaros do not have slotted rotors? Is there a really a difference between slotted/grooved and non slotted rotors? The top two pictures are Camaro non slotted rotors. The bottom picture is the rotor used on Corvettes and the Camaro Brake upgrade package with the grooved/slotted rotor. Thanks.
Walk softly, carry a light saber and drive a ZL1!
05-13-2016, 06:59 PM | #2 |
you talking about slotted or vented?
05-14-2016, 08:26 AM | #3 | |
Drives: 2016 Camaro 2SS 6SP/Suby Legacy 6 Join Date: Oct 2015
TFPK40
Its Here! Finally came home on 3-31-16! Red Hot 2SS,6 Speed, NPP, MRC, Adrenaline Red interior, Silver Rally Stripes, NAV, Sunroof, 56W Split Spoke Wheels, Body color Hood vents, Body color Splash Guards and winter protection package. Ordered 1-28-16: 1100 2-11-2016 :2000 2-15-2016: 3000 TPW of 3/7...That went quick! 2-26-2016: 3400 Status TPW 3/7 3-5-2016 : 3800 3-8-2016 : 4300 3-11-2016 : 4B00 3-15-2016 : 4200 3-22-2016 : 4800 3-29-2016 : 6000! |
05-14-2016, 08:08 PM | #4 |
Use the Force
You are right, I meant slotted/grooved rotors. I attached some pictures above of the NON grooved Camaro rotors and the grooved Corvette rotors. Why are Camaro rotors solid and Corvette rotors grooved/slotted? Is there a difference in performance?
05-14-2016, 08:22 PM | #5 |
i didnt see the pics earlier sorry lol
05-17-2016, 12:21 AM | #6 |
GM repeat offender...
Drives: 16 2SS Join Date: Dec 2014
This is a heated topic. Some will say a "drilled" or "slotted" rotor will cause rotor cracking. Granted, Ive never ran any kind of AutoX, or racing, aside from drag strip and block-brawling, but after AT LEAST a half dozen cars with drilled/slotted(or both) rotors, I have never had a single issue. Even after multiple pad changes. Ive determined over the years that is is mostly cosmetic. But it really makes a diff in the visual dept. Especially with todays larger wheels!
'16 2SS, Summit White. A8. MRC. NPP.
Ordered:09/03/15. Received 12/22/15 INCOMING: ‘22 ZL1, Satin Steel. A10. PDR. Ordered: 03/02/22. |
05-17-2016, 06:31 AM | #7 |
FMPG
Drives: 2016 2SS Join Date: Dec 2015
I'd say that it's not that either "WILL" cause cracking, it's that drilled rotors have the highest probability of cracking or warping. They will dissipate heat the fastest however - and of course they look cool (if that's your thing). Slotted is your safest bet and that's why you see them being used as OEM.
The other thing that I'm going to throw out there is that you should never use caliper covers if you brake hard or are in stop and go traffic during hot temps. They will trap heat and lead to your rotors warping....plus they also look ridiculous.
Ordered 3/8/16- NFG/Ceramic White, M6, MRC, NPP, 6 pots, blk blade, no sunroof, blk splitter, blk bow ties, dark tails, nav.
ARH 1 7/8" ceramic coated full sys w/NPP; Maggie 9.2psi (85mm); Jannetty rough idle cam(TSP), tune and LT4 fuel system; Forgeline VX1 Black PVD (20x10,11); R88R 315's; ALPriority; BMR rear arms, bushings, DS loop; RF intake (red); nGauge 93 octane: 712rwhp, 654rwtq / E85 (E66 mix): 734rwhp, 674rwtq (SuperFlow Dyno) |
05-19-2016, 05:18 AM | #8 |
Drives: Sniffin the tree. Join Date: Apr 2016
I'm thinking one of the usual suspects will be bringing out a slotted rotor upgrade kit soon. Surprised it's not already here actually.
05-19-2016, 05:48 PM | #9 | |
Use the Force
05-24-2016, 10:25 AM | #10 |
Drives: 2016 1SS Join Date: Jan 2016
I think that for the average Joe slotted rotors are just for "show".
Drilled is just a mess with cracking. As for track rats: there is a 100 miles long argument whether slotted are better for the track. Some heavy track rats will just buy "blanks" since they replace them every few events (especially with a heavy car like a Camaro).
1SS, Black, Black Wheels, A8, MRC, NPP
05-24-2016, 10:50 AM | #11 |
I used to be Dragoneye...
Changed the title to reflect the question.
05-25-2016, 05:12 PM | #12 |
Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
As said, drilled rotors will likely crack through hard abuse. The exception will be HIGH end rotors. The cheap stuff will crack.
Slots will wear down brake pads a lot faster than non-slotted. Slots also can make brakes feel more grabby and sensitive than non-slotted, which may be something the average drive may not like. |
05-25-2016, 10:00 PM | #13 |
Use the Force
Thanks Mr. Wyndham, I appreciate the help. With your track experience, do you have any opinions?
05-26-2016, 07:17 AM | #14 | |
Seeing as how the 1LE and ZL1 use smooth rotors, and the 6-piston upgrade uses slotted rotors...I'm going to guess than they did that for looks since people "upgrading" to six piston might be more interested in seeing something special. |
