TireRack
Old 09-23-2014, 12:41 AM   #1
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
shift light. home made
Ok I bought a summit rpm activated switch http://www.summitracing.com/parts/sum-830450-1 and a bright LED https://www.superbrightleds.com/more...ed-light/1494/ I want to do a factory looking shift light. This LED is bright but not so bright from the side. I was thinking of putting it in the dome light console in the drivers side area that looks like a panel. But not sure if it will be bright enough there. I also need to know how to hook the switch up. The directions say to hook it up to the neg side of coil. Will i need a amplifier? Where do you think I could put this led so its not noticable when not in use and looks like it could belong there. I got the black led housing with red led. things blinding bright.
Old 09-23-2014, 05:46 AM   #2
baum
Drives: 2013 1LS, 2013 Ram 1500
good idea!
i think your biggest problem will be trying to hide the led but yet be able to see it. If you put it in the dome light i dont know how well you would be able to see it during the day.
you shouldnt need any amplifier for the tach sense.
baum is offline   Reply With Quote
