10-04-2022, 04:52 PM | #1 |
Drives: toyota camry Join Date: Sep 2022
LT1 Convertible, grippy 245mm tires VS updrade to wider rims/tire
First of all, I used the search function for the forum already regarding the rim/tire option. However, there is not much info from the perspective of a convertible owner. Thus, I think this is a good place to ask for your opinions, and thank you for your input ahead of time!
(1)LT1 (V8) convertible comes with all season 245mm tires on 4 corners, I am wondering how bad this would be for some back road/curvy fun in California? No plans for tracking the car. (2) Assuming I will take the route of upgrading the grip of the LT1 vert down the road. Will swapping for grippy summer tires at 245mm over all 4 corners a good enough options (considering the vert will not be used on track)? In other words, I am not sure going for the SS 245F/275R summer tire setup (with at least 2 new wider rear rims) an overkill, considering a vert is unlikely to be tracked? |
01-10-2023, 02:59 PM | #2 |
Drives: 2023 LT1 convertible Join Date: Jun 2022
I have a similar question.
I have a 2023 LT1 convertible with similar spec'd tires. 245/40R20 all-season Goodyear eagle, run-flat tires No plans to go the track, but I do like taking the car on winding curvy back country roads. I was thinking of purchasing a 2nd set of tires and rims. Maybe SS tires Goodyear® Eagle® F1 245/40ZR20 front and 275/35ZR20 rear blackwall, summer-only run-flat tires. Is it worth it? will it make a big difference in handling and grip? I only drive it in the summer. |
01-26-2023, 08:47 AM | #3 | |
Drives: 2016 2SS Convertible Join Date: Dec 2019
And you don't need runflats. Rougher ride and not worth the extra $$, IMO. Put together a flat repair kit and just count on a tow if it's not fixable roadside, which is what you'd be doing if you shred a runflat beyond just a nail or screw hole.
Hyper Blue/Ash Gray A8 Magnetic Ride Control Dual Mode Exhaust 2019+ version Split Spoke Silver Wheels Navigation Silver Rally Stripes |
02-06-2023, 08:31 AM | #4 | |
Thanks for the Tip TP2SS. I will look into the PS4S. Can't wait until May. I can hear that engine call me now . I'm still at 500 miles and not yet reached the 1500 Miles break in Period. car showed up in the Fall, so tires are still brand new. I will probably use the stock all season for out state cruises and the the high preforming tires for summer spirited driving. do you recommend 19" or 20" for better performance? |
