Old 02-18-2014, 03:33 PM   #29
CRTZL1
Drives: 2013 CRT ZL1
Originally Posted by blake2010ss View Post
I would. I haven't read any oil pump failures from anyone who swapped out
Talked to my performance shop today and he said it definitely wasn't a bad idea, he said most of the stock pumps fail early with 2500 miles or less if there faulty because there flawed from production. So after speaking with him he recommends the 10296 Melling pump if I'm going to do it. I want the peace of mind of the better quality pump. So I just spent some time online finding the best price and I found one for 130.49 shipped! Shop will charge me another 150 to install it. So for less then 300 it's a no brainer
Sent from my SCH-I535 using Tapatalk
CRTZL1 is offline   Reply With Quote
Old 02-18-2014, 08:21 PM   #30
Chevrolet Customer Svc
Chevrolet Customer Svc's Avatar
Drives: GM Vehicles
Originally Posted by ejmjintx View Post
Talked to the dealer tech last evening - new motor on the way in a couple of weeks. When they dropped the pan to change pump, lots of chips - appears the crank buried itself into the thrust washer, all downhill from there.
Thanks for the update. Feel free to let us know how the rest of the diagnosis goes or if you have any questions.
William R.
Chevrolet Customer Care
Chevrolet Customer Svc is offline   Reply With Quote
Old 02-18-2014, 10:33 PM   #31
Camaro Dude
Camaro Dude's Avatar
Drives: ‘13 1LE
Where did you buy that Melling pump from if I may ask?
Camaro Dude is offline   Reply With Quote
Old 02-18-2014, 10:59 PM   #32
CRTZL1
You may......
I got it from AutoZone.Com online, which I was surprised out of the hundred vendors that they were the cheapest with a 20 percent coupon code and free shipping!
Check it out!
Old 02-19-2014, 07:31 PM   #33
S3XPanther
by Odeon
S3XPanther's Avatar
Drives: '12 SS/RS A6 IOM SOLD, '13 1LE IOM
Just another FYI for everyone to consider: another VERY well known LS3 issue (and in fact L99) is a leaking rear main gasket on the oil pan. If your car doesn't sit for long, chances are that you may never even notice a leak. Best way to make sure is to physically get underneath the car and run your hand along the rear of the pan.
"It works 60% of the time, every time."
"Some say it's a waste of time, others say it's an incredible waste of time."
"The ultimate measure of a man is not where he stands in moments of comfort and convenience, but where he stands at times of challenge and controversy."
2013 IOM SS/RS - 1LE. Born 5/6/2013 (1 of 32 1SS IOM 1LE's)
S3XPanther is offline   Reply With Quote
Old 02-19-2014, 07:35 PM   #34
blake2010ss
blake2010ss's Avatar
Drives: 2010 Camaro 2ss/rs
Send a message via AIM to blake2010ss Send a message via MSN to blake2010ss
our ls2 gto suffered from this
2010 Camaro 2SS/RS LS3
1093/1066
416, AGP 6262, E85, Cam
blake2010ss is offline   Reply With Quote
Old 02-19-2014, 07:38 PM   #35
S3XPanther
by Odeon
S3XPanther's Avatar
Damn even LS2's huh? Was it still under warranty?
Old 02-19-2014, 09:51 PM   #36
blake2010ss
Not by the time in started leaking. We still have the car and barely drive it. Its got 20k miles on it and bought it new in 06
1093/1066
Old 02-19-2014, 09:52 PM   #37
Camaro Dude
Drives: ‘13 1LE
You may......
Check it out!
I will I will!!!
Thanks man
Old 02-20-2014, 12:48 AM   #38
CRTZL1
I will I will!!!
Thanks man
Yea buddy!!!
Old 02-20-2014, 06:04 AM   #39
Bu1LEt
Bu1LEt's Avatar
Drives: 2014 Bright Yellow 2SS/RS 1LE
If the LS3 engines are suffering from this how come GM has not fixed this issue yet?
Bu1LEt is offline   Reply With Quote
Old 02-20-2014, 06:12 AM   #40
blake2010ss
Good question. But this has been a gm issue since before the ls3. Just like the crap clutch hydraulics
1093/1066
Old 02-21-2014, 12:06 PM   #41
ejmjintx
ejmjintx's Avatar
Drives: 2013 2SS/RS/1LE
Thank you William. The nagging questions in my mind are
1. The oil pump issues seems to have some history dating back to 2010 and from my recent experience, there still appears to be issues - why hasn't GM addressed this yet? Is it not catastrophic enough in terms of the impact it has on the reliability of the engine, not enough failure count or no good solution is available?
2. It appears that there are alternative pumps that provide more performance and reliability - I realize there is probably an impact in the unit cost to the currrent release, but if you roll in the warranty dollars and voice of the customer is there not a business case to use the alternative?
ejmjintx is offline   Reply With Quote
Old 02-21-2014, 12:36 PM   #42
S3XPanther
by Odeon
S3XPanther's Avatar
Failure count is probably the best bet. You think the LS3 has issues, you should see how bad the LS7 was in it's first two years. I've seen quite a few Z06 owners give up the brand completely out of frustration. And yet, GM still chose to utilize the LS7 in the Z/28.
