07-05-2020, 11:56 AM | #1 |
Drives: 24 ZL1 (4Runner, CRV, Civic, Expl) Join Date: Jun 2020
2021 Camaro ZL1
I was giving some thought to getting a 2021 ZL1 (w/ A10 transmission). In a nutshell, what have been the most common issues, if any, with the ZL1? I could run searches on here and whatnot, but I'm sure some on here could easily point out the main culprits in quick order (again, assuming there are any). Thanks.
07-05-2020, 12:27 PM | #2 | |
Drives: 2018 ZLE Join Date: Feb 2018
2. Hard to wipe the smile away when you get home. 3. That feeling when you decide to press down on the gas. If you can get through these issues I would buy one. |
07-05-2020, 12:41 PM | #3 |
Drives: 19' ZL1, BMW F80 M3 Join Date: Jun 2016
Allow the front seats to recline another inch or two would be nice, but not a deal breaker. A larger supercharger would be great.
Front and rear central jacking points would also be helpful. |
07-05-2020, 01:02 PM | #4 |
Drives: 2018 ZL1 coupe Join Date: Nov 2018
Some oil pump failures on '17-18 cars.
Intercooler circuit is often not filled/bled properly from the factory. You probably wouldn't ever notice this without tracking the car, and it's an easy fix. Have it done under warranty, or $300 aftermarket solution (surge tank in the high point of the system) makes it a non-issue. Jacking points... also easily fixed with aftermarket. Stock brake pads are dusty on the street, and can be a little noisy, but they're designed for hard use. Again, easily solved with aftermarket pads appropriate to your use. A lack of discipline will find you buying tires regularly... |
07-05-2020, 03:09 PM | #5 |
Used to own a ZL1
Drives: '16 Z06 Join Date: Apr 2020
Panel fitment, wheel alignment, and interior rattle are the only issues that have bugged me. They're really not major but it could drive someone critical insane. I wouldn't say it is super common, but I do notice it on many ZL1's I've seen. Other than that the car is perfect. Far less likely to have issues compared to the Z06 for instance.
07-05-2020, 03:17 PM | #6 |
To fast is not enough
Drives: 2019 ZL1 Camaro & 2020 CT5-V Turbo Join Date: May 2019
The back seat is useless, Not enough power, needs about 100 HP then it would be a true super car.. Tires suck got to buy tires ASAP to be able to drive in rain.
07-05-2020, 03:37 PM | #7 | |
Used to own a ZL1
I will admit it could use more power, but the only cars that get away from it really are just supercars. Still quicker than 97% on the road. |
07-05-2020, 04:01 PM | #8 |
Drives: 2019 ZL1 Riverside Join Date: Apr 2020
Is the M5 a supercar?
07-05-2020, 04:13 PM | #9 |
Used to own a ZL1
07-05-2020, 04:41 PM | #10 |
Drives: 2018 Hyper Blue ZL1 1LE Join Date: Dec 2018
The only real issue IMO is the oil pump, and incidents of failure seem to be very low in number/rate. Compared to some other sports cars in the past, I consider this one to be almost trouble free so far. Issues with other cars that come to mind:
07-05-2020, 06:20 PM | #11 |
Drives: ZL1/1LE parts added Join Date: May 2018
Location: Somewhere around Texas pines tress and smooth asphalt
Far less likely to have issues compared to the Z06 for instance.[/QUOTE]
Second this ! Best money a person can spend for a true sports car. |
07-05-2020, 06:24 PM | #12 | |
Drives: 2019 ZL1 1LE Join Date: Dec 2019
Ymmv, Bill |
07-05-2020, 06:25 PM | #13 | |
Drives: CTV5 V Blackwing on order Join Date: Feb 2020
2022 CT5 V Blackwing with A10
2021 GMC Denali pickup with 6.2 and A10 2017 Ford Expedition |
07-05-2020, 06:31 PM | #14 | |
CamaroFans.com
That's crazy talk. |
