dave@hennessey
Old 07-17-2022, 01:11 PM   #1
trodecke
trodecke's Avatar
Drives: 2014 2SS/RS CRT
L99 TO lS3 Conversion - Stuck
Short story, collapsed a DOD lifter in cylinder 4 and when we pulled the head, saw that it had pitted the cam shaft. This is my son's car and he decided that since we're going to be going that far into it (cam shaft replacement), we might as well go the little extra and do an L99 to LS3 conversion along with an upgraded cam shaft. We purchased a BTR stage1 cam shaft and the L99 to LS3 conversion kit from Phastek and have gotten all the way to having removed the bolt for the cam shaft but that's as far as we can get. We can't seem to get any tension off of the timing chain and can't get to the tensioner because of the oil pump. To remove the oil pump means dropping the oil pan to loosen the bolt holding the oil pickup tube but the kit from Phastek didn't include a gasket for the oil pan.
So, is there something else we can do to pull the timing chain (and hence the gear)? Thank you in advance for any assistance.
Lifetime Camaro guy. 1979 Z28, 1987 LT, 2012 2LS, 2014 2SS/RS
--CAI Cold Air Intake
--Solo HFC
trodecke is offline   Reply With Quote
Old 07-17-2022, 03:28 PM   #2
hammdo
'It's an experiment'
hammdo's Avatar
Gotta remove the oil pump. No way around it. Dropping the pan is what it takes…
I’ll link you to one of my build pages…
Also, look for Robert Way’s guide…
-Don
747 RWHP 794 RWTQ
Old 07-17-2022, 03:30 PM   #3
hammdo
hammdo's Avatar
https://www.camaro5.com/forums/showt...=385577&page=5
This is where I started my LSA conversation but also did heads and cam…
-Don
747 RWHP 794 RWTQ
Old 07-17-2022, 03:43 PM   #4
hammdo
hammdo's Avatar
Here you go…
https://www.camaro5.com/forums/showthread.php?t=125123
-Don
747 RWHP 794 RWTQ
Old 07-18-2022, 07:19 AM   #5
trodecke
trodecke's Avatar
Thank you! I'm sure I'll have more questions as this is really pushing my skills and abilities.
--Solo HFC
Old 07-18-2022, 07:39 AM   #6
trodecke
trodecke's Avatar
I was able to get the gear off without removing the oil pump and thanks to Robertway's thread you sent me, I now see how to remove the tension on the timing chain so I can get the new gear back on (hopefully), without too much trouble. I'd seen pictures all over the place of something being placed towards the top of the tensioner to relieve the tension on the chain but I never saw anything that said how to safely put it there.
I hadn't planned on replacing the tensioner, and mine looks pretty much OK, but the consensus seems to be to replace it with the LS2/7 style dampner. What are your thoughts?
--Solo HFC
Old 07-18-2022, 09:08 AM   #7
hammdo
hammdo's Avatar
That is what I did, but to remove that, the pump comes off. I was figuring you were going full LS3 with the 'dogbone' damper. I used the LS7 version in mine initially.
-Don
747 RWHP 794 RWTQ
Old 07-18-2022, 09:39 AM   #8
trodecke
trodecke's Avatar
Thanks!
--Solo HFC
Old 07-23-2022, 06:44 PM   #9
gunchamp
gunchamp's Avatar
Drives: 15 Camaro SS
You only need to pull oil pan bolts and let it drop a little. Dont have to remove it. I did it more than once. Not that bad
gunchamp is offline   Reply With Quote
Old 07-26-2022, 10:16 PM   #10
trodecke
trodecke's Avatar
Update for everyone. We're finally finished. We were able to get the timing chain off and back on again without dropping the oil pan. We started the car up today and I'm not sure if we have a problem or not. We expected CELs and for the car to run rough. We did get CELs but for the things we expected (camshaft actuator, DOD activation failure, etc. It started up OK but I think we have an exhaust leak. It run for about 10 minutes with no problems but then, just as it started coming up to temp, it got really rough. We had to keep it at ~1100RPM just to keep it from dieing. When I checked with my OBD2 scanner (BkueDriver, works really well) I saw good fuel pressure and intake manifold pressure but the short term and long term fuel trims were reading 0.
Is that because we need a tune to drop the AFM and VVT? I'm not a mechanic but I wouldn't think that would cause the trims to read 0.
We're going to have it dyno tuned as soon as possible but that won't be for a week or so.
Thanks in advance for any help.
--Solo HFC
