01-05-2024, 04:03 PM | #1 |
Drives: 2023 2SS Red Hot Convertible Join Date: Jan 2023
Rear license plate centered or not?
When I took delivery of my 2SS the rear license plate was installed slightly off-center. But it didn't bother me.
After fixing an issue, the dealer replaced the rear fascia and re-installed the license plate. This time it was a whole inch to the left, aligning more with the backup camera rather than the center of the car. Once I mentioned this to the service department they showed me another Camaro that had the license plate installed the same way, 1 inch to the left. But then I was looking around and saw another Camaro they had with license plate installed 1 inch to the right. So I have a couple of questions to the community: 1. Is your license plate centered? 2. Is my dealer gaslighting me and they've just incorrectly install all these license plates or there is a technical reason to install it a certain way (left or right)? 3. If the dealer refuses to fix this, and I try to unscrew and screw in the license plate myself, can I damage anything? |
01-05-2024, 04:07 PM | #2 |
Drives: 2016 2SS, 2008 HHR ECTO-2H Join Date: Aug 2009
Sounds like your dealership is filled with idiots.
2016 Camaro 2SS. Hyper Blue, Ceramic White, Auto, MRC, and NPP.
1100 - 9/25 2000 - 9/28 3000 - 9/30 3100 - 10/27 3300 - 10/28 3400 - 10/29 TPW 11/09 3800 - 11/10 4300 - 11/24 4B00 - 11/25 4200 - 12/5 5000 - 12/7 6000 - 12/11 |
01-05-2024, 06:28 PM | #3 |
They are gaslighting you all right, and don't have the patience or ability to install the rear license plate correctly.
The rear bumper has a number of dimples to aid in positioning the plate, because the bumper is made the same for all markets with different license plate sizes, and I guess the dealer just picked four of these indents that "felt right", apparently not the correct ones...
01-05-2024, 06:41 PM | #4 |
Drives: Wild Cherry LT1 Join Date: Dec 2016
Lazy-incompetent-gaslighters…
01-05-2024, 07:29 PM | #5 | |
01-05-2024, 07:39 PM | #6 |
If you remove the license plate and look behind, there are several precast dimples for different plate formats, it is actually very difficult to screw that up
01-06-2024, 05:57 PM | #7 |
I see no dimples. It's a flat surface. But I see a few tiny indentations at random locations. See photos. It doesn't look like there are any "predefined" locations for screws.
Also attaching the positioning of the plate as it is now. The green line is the symmetry line. Yellow and purple lines are same length. The difference in real world between these two lines is about 0.5 in. |
01-06-2024, 06:54 PM | #8 |
The clusters of indentations are a reference for different countries license plates. Just hold your plate up to where you think it’s centred on the car and see if any of those indentations lineup with the holes in your plate. An insert is not required to mount the plate. You can simply use a quality stainless screw if it bothers you enough that you want to relocate it. My guess is the dimple with the arrow to the right of the left side hole is most likely the correct location for the plate
01-06-2024, 08:39 PM | #9 |
Drives: 2014 Ford F-350 Join Date: Sep 2023
Britain Chevrolet got mine right!
2024 Red Hot 2SS 1LE w/BCD, PDR
2014 F-350 Crew Cab Cassis Cab Dually 6.2L w/4.30 2014 Hyundai Elantra GT 1995 Buick Roadmaster Estate |
01-06-2024, 09:13 PM | #10 |
As CalgaryZL1 said, those indentations you see are the dimples we were talking about, and you will find a cluster of 4 that perfectly line up with the holes in the US license plate.
On a side note, what bothers me is that the backup camera is not centered, so there is an offset on the screen, too, that I have to compensate for when parking. Since I drive other cars, too, I occasionally forget about this. Very minor first world problem, though.
01-07-2024, 09:01 AM | #11 |
Drives: 2019 zl1 6 speed Join Date: Jul 2017
Is that why I'm always parking over thr parking spot line!? Hah, I never noticed this somehow.
01-07-2024, 09:30 AM | #12 |
Drives: Chevy Camaro Join Date: Dec 2019
I had the same problem on mine - I hadn't noticed it until about 5 months when my son pointed it out... I took it off and drilled the screws into the "correct" spot.
I did fill in the wrong holes with some exterior clear caulk I had to avoid water from getting in. Good luck! |
01-08-2024, 09:05 AM | #13 |
Drives: 2023 Camaro 1SS Join Date: Apr 2014
Holy moly , a trailer hitch on a Camaro?! WTF
01-08-2024, 05:34 PM | #14 |
