04-11-2024, 06:39 AM | #1 |
Camaro #4
Drives: 2017-Hyper Blue Metallic-2LTmanual Join Date: Dec 2015
Found the perfect switch/relay for kill switch
Wireless Remote Switch
Found it on Amazon, $20 with next day shipping. The switch/relay is programmable and has several options. On only when the button is pressed, one button on/off, two button on/off and 4 timed options for 5 / 10 / 15 / and 20 seconds, then it turns the relay off. I'm not going to say how I'm wiring it in, but the unit can be placed anywhere in the car and totally concealed. The hardest part (for me) will be deciding which program to use.
Don M
Supercharged LGX + 6 speed manual = FUN!! |
04-11-2024, 09:57 AM | #2 |
Drives: 2022 Camaro 1SS 1LE Join Date: Nov 2021
Nice. I should install this in addition on the fuel in addition to the mobilistics on the starter.
I need to get power to my dummy obdii port so that the theif plugs in and sits there fiddling for a while.
2022 Camaro 1SS 1LE 6-speed
04-11-2024, 12:27 PM | #3 | |
Drives: 2023 Camaro 2SS Join Date: May 2022
Where did you get the dummy one? I got one but it doesn’t fit in the space. Sent from my iPhone using Tapatalk Pro |
04-11-2024, 01:19 PM | #4 |
Drives: 2000 WS6 Join Date: Dec 2014
There's a link in the DIY thread for a dummy OBD with the correct profile to click into place under your dash. Only real difference is it has all 16 pins, not just the OEM 8 pins populated.
04-11-2024, 02:42 PM | #5 | |
Went looking in the DYI. Must have missed it. Do you happen to have the link? The one I bought was from the one posted here in general section. It doesn’t fit though. Too small. Sent from my iPhone using Tapatalk Pro |
04-11-2024, 02:55 PM | #6 |
https://www.camaro6.com/forums/showthread.php?t=623413
Post #1, link to OBD2 Pigtail. https://www.amazon.com/dp/B0B213F7N1...roduct_details |
04-11-2024, 10:27 PM | #7 | |
Drives: 2023 Camaro Convertible ZL1 A10 Join Date: Mar 2023
Or if you put power to all the connections it would ruin their device |
04-12-2024, 11:35 AM | #8 | |
Essentially it would just have power to turn it n their machine so it looks to them it’s correct, but it wouldn’t have the wires connected to talk to ecm. So it would confuse the thief’s more hoping they give up and just leave because they couldn’t figure it out. Sent from my iPhone using Tapatalk Pro |
04-17-2024, 05:59 AM | #9 |
Drives: 2019 2SS Convertible Camaro Join Date: Mar 2012
\(^^^)/ <--A Smile From He11
Escort 360 MAXX w/DIYGen5 hardwire Harness K&N AirCharger Cold Air Intake Sound Tube Delete |
