09-02-2023, 03:46 PM | #1 |
Drives: 2023 Riverside Blue 2SS Join Date: Sep 2022
Is there a performance difference between E70 and E85?
I’m running the Flex fuel kit and most places by me are E70 and E85 is about 30min away. Is it worth getting actual E85 or is E70 fine?
09-02-2023, 04:53 PM | #2 |
Drives: like an old lady Join Date: Jun 2012
what's the setup?
the only thing id consider is fuel quality. the na bolt on car i had ran the same on e65 or e83, didn't matter.
2016+ camaro: everyone’s first car
09-02-2023, 05:17 PM | #3 |
Although I haven't seen back to back dyno sheets from the same car using fuels with different ethanol contents, but based on several tuner's comments, diminishing returns start kicking in after 50-55% ethanol and almost all the extra power to be had is attained already at 70%. Increasing octane level no longer helps much beyond a certain point.
I'd just keep pumping E70 and enjoy 99% of the car's max performance, not worrying about E85.
09-03-2023, 01:50 AM | #4 |
there is a lot to consider with ethanol ratings. i used e85 all summer long and rarely saw over 80% ethanol content. it mostly hovered around 75. there is also a seasonal dependent minimum ethanol content schedule based on region. most pumps operate on the minimum or close to it. speedway & meijer (around here) offered the highest content. thorntons was among the worst.
i monitored mine via hptuners & a factory gm ethanol content sensor.
09-03-2023, 07:37 AM | #5 |
Snackbar Tuning
E70 is plenty for a street car and you can throw a lot of timing at it. At a certain point, you wont go any faster E60 vs E70 vs E85 vs E90(ignite).
I would bet that you can put max timing into the car by E70 and you wont go any faster on E85. I actually change most of the cars I tune for E to have max timing by E70 instead of E80. |
09-03-2023, 07:47 AM | #6 | ||
09-03-2023, 09:57 AM | #7 |
Drives: 2022 Camaro 2SS 1LE Join Date: Nov 2021
Some say that the car seems to run better with some sort of mixture. I have 2 people I meet up with that say even though they can go full E they get better response and gas mileage doing some sort of mix.
p1sc1 factory box w/ stage 2 intercooler, Lt4 fueling, JMS BAP, lt2 intake, kooks 1/78 longtube headers w/ h/f cats, alky meth kit, thpsi port injection
09-03-2023, 10:08 AM | #8 | |
Drives: 2019 Camaro Z-28 Join Date: Jul 2010
E85 at the pump is rarely true E85. I have an AEROSPACE gauge and the E85 I buy at the pump (KROGER) is REALLY about E78. NOTE: More timing doesnt necessarily make you go any faster. Typically tuners will give a car more timing until the car DOESNT make any more additional power then they back off usually 1-2 degrees.
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 |
