Old 07-20-2023, 12:33 AM   #1
Saberscar223
Saberscar223's Avatar
Drives: 2023 Riverside Blue 2SS
What would I need to do to comfortably be over 700hp on an LT1?
I want to boost the car but I’ve heard the engine can’t handle anything over 650WHP without upgrading internals. Exactly what would I need to replace to handle ~ 700whp? And would the 10L80 need to be upgraded or replaced too?
Saberscar223 is offline   Reply With Quote
Old 07-20-2023, 12:49 AM   #2
Need4Camaro
Drives: '17 Camaro 2SS & '99 Camaro Z28
Honestly, I would just buy a ZL1 and a pulley.. ..much less headache, much less involved, and probably less expensive. After you look back at the receipts and realize you could have bought a ZL1, you will be kicking yourself.
Need4Camaro is offline   Reply With Quote
Old 07-20-2023, 01:56 AM   #3
waterman
waterman's Avatar
Drives: Grandad's C2 L89
Absolutely, with upgraded internals and FI already in place... and a warranty.
2018 ZL1 1LE sw/PDR
waterman is offline   Reply With Quote
Old 07-20-2023, 07:04 AM   #4
arpad_m
arpad_m's Avatar
Drives: 2018 Camaro 2SS A8
I'm not kicking myself at all, even though I did spend ZL1 money on my SS. Then again, it has 200 crank hp more than a stock ZL1 (pulling like a freight train), and looks exactly the way I want, inside and outside (I still glance back at it every time I park somewhere, even after 5+ years).
There is no one size fits all solution.
735 rwhp | 665 rwtq
3000 - 2/06/18 TPW 2/26/18
arpad_m is online now   Reply With Quote
Old 07-20-2023, 07:09 AM   #5
adamjwilson
Drives: 2022 Camaro 2SS A10
Good thought but the ZL1 falls short of 650rwhp is stock form.. more like ~580ish rwhp. OP asked what he needs to do to go over 650rwhp, OP may want to consider forged internals.
If not, then keep the boost low 8-9PSI on the stock SBE, add a flex fuel kit, run E85, find a good tuner if you want it to live any life.... (but that is not guaranteed either)
Build it and mod it your way and make it your own
DSX Flex Fuel/ Meth Injection/ Katech 112 TB/ RotoFab Big Gulp/ Corsa NPP/ Various exterior mods
adamjwilson is offline   Reply With Quote
Old 07-20-2023, 07:11 AM   #6
FarmerFran
FarmerFran's Avatar
Tires, definitely tires
2023 Camaro ZL1 Vert TR-6060 Sharkskin "Sharky"
Firecracker Red Wrangler Willys, 3.6L eTorque, 850RE 8 speed automatic, 25W Willys package, Technology Group, Convenience Group (aka $600 garage door opener), Cold weather Group, Trailer Tow and HD electric group with AUX switches, 3 piece black freedom top.
Old 07-20-2023, 08:51 AM   #7
BlackbeastSS2
BlackbeastSS2's Avatar
Drives: 2019 Camaro 1LE Shock Candy
The OP questions was what would he need to do to be comfortably over 700hp on an LT1? Forge the engine/cam/heads/fuel system and 1.7 supercharge it.
Used 2022 prices - Edmunds Suggested
2SS $43,695 $42,904
ZL1 $65,895 $65,084
You have a little over $23K to play with price difference. It will no where be near stock ZL1 - suspension wise/rear end/ etc but it will have a lot more power. $23K u can make a very fast Camaro SS over 700 RWHP easily. Go for it if you like modding, if you don’t get a used ZL1 with 650 Hp to the flywheel. No need to upgrade tranny.
There’s lots of threads on builds here to achieve your goal.
LT4 1.7 Supercharger snout ported & Meth
103 Katech TB, KATECH Custom Heads, DSX In-line fuel
TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM
Diamond Piston & Manley Rods, Roto Fab Big Gulp
BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats
SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane.
2014 Mini Cooper countryman S All4 M6 daily driver
BlackbeastSS2 is offline   Reply With Quote
Old 07-20-2023, 08:56 AM   #8
18.2SS.1LE
18.2SS.1LE's Avatar
Drives: Chevrolet Camaro
Seems the way to go now would be Laynlo's route. Port injection, E85, blower, headers will get you there on an otherwise stock engine. Not sure if he's running a JMS BAP or what's on the low side though. If I were to do it again I would've skipped the LT4 fueling and went the port injection route.
Procharger P1X, CSP Big Boy Cam, CSP Headers, LT4 HPFP, LT4 Injectors, JMS BAP - 722WHP
18.2SS.1LE is offline   Reply With Quote
Old 07-20-2023, 01:38 PM   #9
laynlo15
laynlo15's Avatar
Drives: 2022 Lt1 A10
Yes sir, exactly the way to go, I've been running mine for almost a year now. We have it dialed in really well and way cheaper then buying a Zl1, plus you can do it on the stock Lt1 fuel system as I have. I can run up to E70 on my current setup, but our stations seem to be limited to E65 to E67 on my HPT logs. The only thing I have is a JMS voltage booster to help the low side out at WOT. Mine is a very simple setup, got a used 2300 Maggie from Superchargers Onine, TooHighPsi Port injection and RotoFab CAI. No other mods that enhance performance. We made 707 rwhp and 669 rwtq on 11 psi of boost. So, no internal mods required, no exhaust mods needed. Ran best Et of 9.80@142.96. Can't beat that.
Old 07-20-2023, 01:43 PM   #10
laynlo15
laynlo15's Avatar
You won't need to upgrade the engine or trans if you do a 2650 Maggie and TooHighPsi Port Injection. I did have my TCM unlocked but we've done very little to it, just enough to keep GMs torque limits from screwing with our tune and pulling timing on the launch.
Old 07-20-2023, 05:39 PM   #11
FlukeSS
FlukeSS's Avatar
Drives: 2020 Camaro 2SS A10
I do too
'ing for New Engine.
She still wimpers to me, but I just can't explain why not.
2020 Camaro 2SS A10 | Rebuilt by: CBI Street Cars | 2" SE LT Headers | 3" SE X-Pipe | 3" MBRP Axle-Back | Pri & Sec Cat Deletes | K&N Typhoon CAI | LT2 Ported | 95mm ZR1 TB | DOD Delete | BTR Stage I Cam | ECM, TCM & E85 |Tuned by: Shane Hinds | Dyno: 510 rwhp 472 rwtq
FlukeSS is offline   Reply With Quote
Old 07-22-2023, 05:36 AM   #12
LancevanceZLE
Drives: 2019 ZL1 1LE
The problem is you don't get the money for the mods back. Mods depreciate by 70%, while a ZL1 will hold its value, so in the long run it's cheaper to buy a ZL1 and do some minor mods than spend $25k on mods on a $40k SS. That SS is not going to sell for $65k after you're done modding, more like $45k at most. Also, of the $25k at least $4k would be spent on wheels and tires because stock SS tires cannot handle 700whp.
A lot of people say they don't care about resale value because they'll keep the car forever, but I've rarely actually seen someone keep a car forever.
Buy the best platform you can get and start modding that. That's a much wiser decision.
LancevanceZLE is offline   Reply With Quote
Old 07-22-2023, 06:32 AM   #13
Chevelle vs Camaro
Chevelle vs Camaro's Avatar
Drives: 2018 Camaro SS
I’m missing the part where he asked if he should buy an ZL1 instead. He asked for build info not financial info on what to buy. Y’all bought a ZL1 because that what was right for you….
Y’all assume OP didn’t think about that?
OP you would need to to do forged pistons and rods. Possibly a crank. I’m not on it though I would call a shop in the know and ask them…. Like Texas Speed.
Chevelle vs Camaro is offline   Reply With Quote
Old 07-22-2023, 06:57 AM   #14
arpad_m
arpad_m's Avatar
I don't see a sea of SS owners flooding ZL1 threads with "OMG you shouldn't have spent $20-22k extra on your car, you should've just slapped a Maggie and a tune on a 2SS for $9k and have the same powaaah".
To the contrary, every time someone asks about SS build/mod info, one or more ZL1 owners come in with unwarranted financial advice and questioning how "smart" the OP was for not buying the ZL1 in the first place. Leave the man be and let's help him instead.
As for the build, my info is in my sig, it's a rock stable 735 rwhp (on E60) car, a perfect Jekyll and Hyde build by Jannetty Racing.
735 rwhp | 665 rwtq
