03-16-2023, 11:29 AM | #1 |
Drives: 2023 Riverside Blue 2SS Join Date: Sep 2022
Suggestions for getting Cams?
So this is my first Camaro and my first V8 in general how complicated is it to get a cam Upgrade? I’ve heard I need to get a Torque converter and all sorts of mess before I do cams is this true or can I just buy a Cam take it to a shop and tune it?
Also how much can I expect to pay for getting a cam installed on a 6th gen ten speed? |
03-16-2023, 01:03 PM | #2 |
Shadow Gray '19 ZLE M6
There is only one camshaft in a pushrod, overhead valve motor like the LT1
You'll need the new cam, supporting valvetrain mods (valvesprings, retainers, pushrods, timing chain, lifters, etc.). Might as well do AFM/DOD delete and Katech oil pump at the same time. Plus install labor costs. Plus dyno tune. Best bet is to speak to a specialist LS/LT shop that will recommend a package for you. Talk to them about your goals with the car (purpose, HP target, etc.) to get the best recommendation. I don't know any shops in Colorado, but some of the most respected shops nationwide are Jannetty Racing, Katech and Vengeance Racing, among many others. This thread has a lot of info and great pics to give you an idea what the install entails. Granted, this is an LT4, but most of what you see is still applicable to the LT1. You can skip over the supercharger-related posts.
03-16-2023, 01:06 PM | #3 | |
My general rule of thumb is $100 / hp gained Some mods are better than this rule, but just a guide. $4500 ? Any other guesses?!
2018 Camaro SS 1LE - 2011 370z - 2004 VW R32 - 2000 Civic Si Mods: Rotofab, Nick Williams 103mm TB, MSD IM, Kooks 1 7/8 Results: 470 hp / 447 tq |
03-16-2023, 02:20 PM | #4 |
Drives: Ferrari F40 Join Date: Sep 2022
Yea, I think around that is fair for a cam install + tune, but that pricing doesn't really translate to forced induction. A stock brand new SS will dyno around 400whp +- 20hp, supercharged can safely reach 600whp, so around 200whp increase. It doesn't cost anywhere near $20k to supercharge an SS.
03-16-2023, 02:25 PM | #5 | |
You took the time and math to correct me but NOT answer the man's question?
03-16-2023, 02:25 PM | #6 |
Btr 220 or btr225 seems to be the interesting options at the moment
03-16-2023, 02:33 PM | #7 |
Not 100% sure about the LT1 but if you are going CAM might as well get heads.
2023 Camaro ZL1 Vert TR-6060 Sharkskin "Sharky"
Firecracker Red Wrangler Willys, 3.6L eTorque, 850RE 8 speed automatic, 25W Willys package, Technology Group, Convenience Group (aka $600 garage door opener), Cold weather Group, Trailer Tow and HD electric group with AUX switches, 3 piece black freedom top. |
03-16-2023, 02:35 PM | #8 | |
I honestly think the best advice here is just to call a few pro shops and see what packages they offer.
2020 Camaro 2SS A10 | Rebuilt by: CBI Street Cars | 2" SE LT Headers | 3" SE X-Pipe | 3" MBRP Axle-Back | Pri & Sec Cat Deletes | K&N Typhoon CAI | LT2 Ported | 95mm ZR1 TB | DOD Delete | BTR Stage I Cam | ECM, TCM & E85 |Tuned by: Shane Hinds | Dyno: 510 rwhp 472 rwtq
03-16-2023, 02:37 PM | #9 |
03-16-2023, 02:40 PM | #10 |
Yes - if you look at the flow/lift curve you will want to port to take advantage of the added lift. The heads won’t show additional flow above the factory cam lift. Katech will do the ports for 5-600
03-16-2023, 02:44 PM | #11 | |
His best bet would be to ask this question in the appropriate subforum not here.
2016 NFG 1SS A8
03-16-2023, 02:47 PM | #12 |
I will say this, save yourself some money and get it all done at once. I wish I would have when I built out my 2004 GTO. Do cam, heads, headers, exhaust and a tune.
But seeing you are at elevation, a SC would be a better choice
03-16-2023, 03:10 PM | #13 | |
Drives: 2022 Camaro 2SS A10 Join Date: Jul 2022
RAMAir02 provided some quality shops if you are looking to get the work done for you.
DSX Flex Fuel/ Meth Injection/ Katech 112 TB/ RotoFab Big Gulp/ Corsa NPP/ Various exterior mods |
03-16-2023, 03:23 PM | #14 |
I was thinkin the same thing tbh.
